Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. May 30, 2020 at 2:33 PM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Passenger side is off!
    My Name is Rahl and fleckosaurus like this.
  2. May 30, 2020 at 4:40 PM
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    There may be extra wood but I’m not sure yet. I’m using the post to replace my old porch posts.
    I’ll need someone good with electric when my new building is up. It has to “pass inspection” for Owen electric to hook the wires back up to the pole
  3. May 30, 2020 at 4:45 PM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Before:
    During:
    After:
    Now I just need to trim that new center pin, paint a few areas with the Rust Reformer, install the new U bolts and new shocks and I’ll be done with one side. Damn, I’m slow...
    EdinCincinnati and rdpoe like this.
  4. May 31, 2020 at 3:04 PM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Finally done with the rear suspension. Just need to torque the struts and U bolts once the truck is back on the ground.
    Passenger Side:
    Driver's Side:
  5. May 31, 2020 at 3:15 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Looking super clean, dude
    My Name is Rahl likes this.
  6. May 31, 2020 at 3:58 PM
    My Name is Rahl
    Damn. Looks new!
  7. May 31, 2020 at 5:22 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Looks Awesome!!!
    Definitely better than WD40!!
    TRDZILA and My Name is Rahl like this.
  8. Jun 1, 2020 at 6:44 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    I’m having problems with getting my windows to roll up or down. It’s been going on for awhile. When it first started I could open the drivers door and they would start working. That isn’t fixing it anymore. Has anyone else dealt with this?
  9. Jun 1, 2020 at 6:52 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I pushed the door lock button and they work now. Maybe I can get a couple more years out of them.
  10. Jun 1, 2020 at 6:55 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    That’s an odd one. Makes me think your switch panel has a short or is failing. I haven’t had issues with my windows but I have noticed the door lock on the driver’s door doesn’t move. The door locks and unlocks just fine and thankfully it opens but the little red/black thing stays in the same place.
    TRDZILA[QUOTED] likes this.
  11. Jun 1, 2020 at 6:57 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    Gremlins......
  12. Jun 1, 2020 at 7:02 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I’m going to Haspin Acres this Thursday to chase a couple of SXS’s around.
  13. Jun 1, 2020 at 7:04 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I had a driver door window switch failure. Bought a replacement on eBay and that fixed it.
    TRDZILA likes this.
  14. Jun 1, 2020 at 7:08 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Pull the door panels and take a peek at the switches and connections.
    Troubleshooting step; try to use the passenger switch to roll up that window, if it does better than driver side, then that is likely your culprit.
  15. Jun 1, 2020 at 7:09 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    When it’s acting up none of the window switches work.
  16. Jun 1, 2020 at 7:14 AM
    dirty deeds
    Nick
    Eastern KY
    Ah, well, the only option is fire at that point. lol
    Or a bad relay? Possibly just a crusty connection too.
    If you do chase it all down and take things apart, get some dielectric or No-Oxide A grease
    Here's what we used in my telecom days https://www.amazon.com/NO-OX-ID-Tube-Special-Grease-Compound/dp/B00HSW341A
  17. Jun 1, 2020 at 7:26 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    That’s what makes me think it’s the driver’s side door panel switches (or connection). Since none of the other windows will work when the window lock button is depressed the panel could have a loose wire or short causing all the windows to not work.
  18. Jun 1, 2020 at 7:39 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    That’s what I’ve been thinking also. I took it apart and cleaned the contract’s with electrical cleaner and it worked good for awhile. I’m going to order a new switch and see what happens.
  19. Jun 1, 2020 at 9:53 AM
    dirty deeds
    Nick
    Eastern KY
  20. Jun 2, 2020 at 4:23 PM
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Does anyone know if a little water in the front speed sensor hole in the knuckle may hurt anything? I forgot I had a foobar speed sensor so I cut the wing off an extra left one I had an stuck it in the right side until I could get an OEM one. Forgetful me drove up and down a creek. I just pulled the sensor and there's a little moisture on it now. Brand new bearing in there that I don't really want to mess up.
