Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Jul 9, 2020 at 5:37 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Didn't know you could get 4.33? Get at least 4.10, but idk the recs for an auto v6 sizing up tires.
    Here's the wheel bearing dude https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-prerunner.537080/
    TRDZILA[QUOTED] likes this.
  2. Jul 9, 2020 at 5:50 AM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    05Taco4x4
  3. Jul 9, 2020 at 6:01 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Thanks. I’ll order mine today.
  4. Jul 9, 2020 at 6:05 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
  5. Jul 9, 2020 at 8:32 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Before my health went to shit, I did my own re-gear. Started off with stock 3.73s (v6/auto) With 33" tires , (Cooper 285/75r16 STT PROs at that time) I got within 2% of what stock gearing/stock rubber offered (rpm @ 60 mph) with no more than 4.10s.
    I'm 100% pleased with the outcome. Durable, very "streetable", didn't adversely effect gas mileage and performs well off road.
    TRDZILA and Roll Tide like this.
  6. Jul 9, 2020 at 12:45 PM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    In pretty sure I have a 382 gear ratio. It was fine with the stock 265/70/16 but kinda took a dump with one size bigger. It was really a dog when I had 33 mt’s on it.
  7. Jul 10, 2020 at 9:32 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    So.... seriously, FML :frusty:
    I took today off work to try to actually get stuff done on the truck. And I can’t even get the f*cking skid plates off. Three of the four bolts came out, no problem. Fourth one started to come loose and then gave a loud pop. Now it just spins freely...
    And it’s one of the front bolts that goes through the TRD skid plate, through a bracket, a spacer and then through the factory skid plate into the brace on the subframe. I’m guessing, because I can’t see it, that the weld but on the bracket broke off and now the whole bolt and nut assembly are just spinning.
    I have no idea how I’m going to get these skid plates off now...
  8. Jul 10, 2020 at 9:39 AM
    dirty deeds
    Nick
    Eastern KY
    This happened to me, too.
    But was on the OEM front splash guard, because they really aren't "skids". One of the 2 rear bolts, the nut broke free of the welds. Some heat, lots of pen lube, and holding my tongue right, I was able to get a wrench to hold the nut enough to get the bolt out. It was frustrating as hell, but I got it done.
    Don't give up! Look at the holes in the frame and sub frame, you'll find a way in. Or not. Then just :sawzall::welder:
    Needless to say, my actual skid only has 4/6 bolts holding it on. Mated to the mid skid, it doesn't move much.
  9. Jul 10, 2020 at 9:44 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Yeah, I just stuck my head up there and confirmed. The weld nut broke free... the entire bolt and nut assembly just spins when I turn it. No idea how I’m going to get it out. Can’t really get the sawzall in that far with the skids still on and can’t cut the head off without damaging the powder coated aluminum...
    My Name is Rahl likes this.
  10. Jul 10, 2020 at 9:53 AM
    My Name is Rahl
    Can you make a tool to hold the nut?
  11. Jul 10, 2020 at 9:55 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    One way may be (if you can hold the bolt still) is to drill into the center of the head progressively larger until the head just falls off. Shouldnt touch the skid at all.
    dirty deeds and My Name is Rahl like this.
  12. Jul 10, 2020 at 10:12 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Thank god I have long ass arms... I got it off. Reached up in there and clamped a small pair of vice grips to the broken free nut. Hit the bolt with my impact and it spun it right out.
    The bolt is undamaged but all four need to be cleaned up and hit with anti seize before they go back in. Now I’ll just need to figure out how to mount a new nut for that front left bolt...
    TRDZILA and My Name is Rahl like this.
  13. Jul 10, 2020 at 10:14 AM
    My Name is Rahl
    You could leave it out, unless you have a welder and can tack it back on there.
  14. Jul 10, 2020 at 10:18 AM
    dirty deeds
    Nick
    Eastern KY
    This. Leave it out.
  15. Jul 10, 2020 at 10:29 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Meh, I like the look of the TRD “skid plate”
  16. Jul 10, 2020 at 10:41 AM
    My Name is Rahl
    He meant the bolt.
    dirty deeds likes this.
  17. Jul 10, 2020 at 10:53 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Oh yeah, I can make that work for sure.
  18. Jul 10, 2020 at 10:58 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Fluid Film the truck and that wont happen again.....
  19. Jul 10, 2020 at 12:02 PM
    dirty deeds
    Nick
    Eastern KY
    Leave the bolt out, I mean.
  20. Jul 11, 2020 at 7:58 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    So this should spark some fun discussion...
    Anyone have suggestions for what I should do with this? :rofl:
    I took it out to make the suspension swap easier and give me a little more room to work with the power steering rack. One of the end links was also seized to the spindle so I had to cut it out anyway...
    And, in reality, I’m probably going to install new end links (I already have Moog replacements) and put it back in the truck after I’m done with the power steering rack. But I know it’s a heavily debated topic on TW...
