Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Sep 15, 2020 at 1:01 PM
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    Electrical tape and send it :fingerscrossed:
    dirty deeds likes this.
  2. Sep 15, 2020 at 1:24 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    If you would've seen my wiring before hand, you would have noticed how that's exactly what it was.
  3. Sep 15, 2020 at 2:23 PM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    A few wire nuts in there for good measure. Oh wait, that's me....
  4. Sep 15, 2020 at 2:49 PM
    Summers_Kytaco_19
    Steven
    Independence, KY
    19 trd OR tacoma
    Just fill them with some flowable sealer and it’ll be fine
  5. Sep 16, 2020 at 5:55 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    It gave me anxiety AF
  6. Sep 16, 2020 at 5:56 AM
    MedlinAround
    Cody
    Kentucky
    If something has a hot and a ground, it'll work!
  7. Sep 16, 2020 at 5:58 AM
    dirty deeds
    Nick
    Eastern KY
    ...and also burn your truck to the frame :bananadead: :rofl:
  8. Sep 16, 2020 at 6:48 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Speaking of rigs burning to the ground... one of my CH4x4 switches MELTED the night of rush causing my light bar to get stuck on lol. i had to go flip my master breaker.
    CH4x4 said something about using a relay in line from the battery? Can anyone point me in the right direction?
  9. Sep 16, 2020 at 6:52 AM
    dirty deeds
    Nick
    Eastern KY
    They're right. Anything pulling that much juice needs a fuse and relay, not a direct power source. Anything over ~5 amp draw.
    https://www.ch4x4.com/product/ch4x4-12v-20-30-amp-relay-with-5-pin-harness/
    https://www.ch4x4.com/product/ch4x4-marine-grade-waterproof-12v-40-amp-relay-with-5-pin-harness/
    Or you can likely get something similar to the above for cheaper at your local parts store, just need a harness.
  10. Sep 16, 2020 at 6:54 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I have a fuse inline for each one of my switches.
    Thanks man - i'll check it out
  11. Sep 16, 2020 at 8:00 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I've used this to make the relay half of the circuit, and to keep things tidy vs the panel mounted setups I've seen.
    That said, the 1:1 fuse to relay ratio means you are short a few fuses :( so I also have a cheap blue sea fuse box. It Also doesn't have good bus connectors/room for good bus connectors, so they might get a little sketchy... but contained within ABS box = not a lot of risk
    If you are spendy, I'd recommend a nice bussman box over anything else.
    b3itz likes this.
  12. Sep 16, 2020 at 8:30 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Can you help me understand where the relay goes in the circuitry and what value it adds. I know i've read about it, but it never clicked.
    I'm using a blue sea fuse block now where the block is directly to the battery, and then all the switches are fused off the block.
    Edit: the fuse block actually has a 150amp breaker between it and the battery. I flip that sucker on before activities happen
  13. Sep 16, 2020 at 8:37 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    I got this:
    Relays are switches that open and close circuits electromechanically or electronically. Relays control one electrical circuit by opening and closing contacts in another circuit. As relay diagrams show, when a relay contact is normally open (NO), there is an open contact when the relay is not energized. When a relay contact is Normally Closed (NC), there is a closed contact when the relay is not energized. In either case, applying electrical current to the contacts will change their state.
    Relays are generally used to switch smaller currents in a control circuit and do not usually control power consuming devices except for small motors and Solenoids that draw low amps. Nonetheless, relays can "control" larger voltages and amperes by having an amplifying effect because a small voltage applied to a relays coil can result in a large voltage being switched by the contacts.
    Protective relays can prevent equipment damage by detecting electrical abnormalities, including overcurrent, undercurrent, overloads and reverse currents. In addition, relays are also widely used to switch starting coils, heating elements, pilot lights and audible alarms.
    From this website: https://www.galco.com/comp/prod/relay.htm
    Basically, relays are a bottleneck (closed) or a gate (open) in the system to make sure other systems get the correct amount of power. I think....lol.
  14. Sep 16, 2020 at 8:53 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Basically that^.
    Relay = high load switch thats controlled by a small load switch (rocker/ push button etc) that you, the operator change the position of.
    Most switches are rated for low loads, ~5amp, some rockers claim 20amp, but thats for like a 5% duty cycle (meaning you have the thing switched on for a few seconds an hour), so just like what happened to you, it will work when you test it for 30 seconds in the garage, but when left on all night out on the trail, the switch will fail.
    Even some of the relays out there are rated for 30 or 40 amps at a certain duty cycle for a set temperature range, so its also important to spec the relay according to the temperature it could be used at. ( I recently had a 40 amp relay fail under a 25amp load due to the working temperature and being 100% duty)
    the NC and NO thing is as @Roll Tide copy pasta'd, for the most part you will want NO relays (or really the bosh 87/87a thats always used by everyone) for all these auxiliary device applications.
    MJTH and dirty deeds like this.
  15. Sep 16, 2020 at 11:49 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    What does everyone do for shock rebuilds/service around here?
  16. Sep 16, 2020 at 11:54 AM
    dirty deeds
    Nick
    Eastern KY
    Good infos ryechere boys :cheers:
    I've got most things (that need it) on relays, from the Blue Sea fuse panel, with a Bussman breaker between the battery. Only 2 things I run right off the battery is the CB and winch, both have respective fuses and whatnot. The only slightly sketch wiring job I have is my ditch lights, suckers are so low powered I didn't relay them, just a fuse. Something like 2 amp draw.
  17. Sep 16, 2020 at 11:56 AM
    dirty deeds
    Nick
    Eastern KY
    When you find out, lemme know!
    I contacted a place east of me in WV. Cost was NOT worth it, including shipping/labor/parts. When my rear Foxes go out, I'll likely just buy another $300 pair of em.
  18. Sep 16, 2020 at 12:28 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
  19. Sep 16, 2020 at 12:59 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    buy new replacement
    MJTH likes this.
  20. Sep 16, 2020 at 1:02 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I also have my fogs and or Rock lights wired straight to a "20a" rocker switch with similarly low draw.
    Since everyone seems to think that way...
    I might start offering.
    dirty deeds[QUOTED] likes this.
