Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Oct 21, 2023 at 12:18 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I’ve been really happy with the Yoko G003s
    pizza cutters.
    great on road. Wet, ect. Phenomenal offroad. Piss poor in snowy roads. Expected.
  2. Oct 21, 2023 at 5:25 PM
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Yea....I probably should have
    That's probably what I'm going with, expect 285/70, why did you decide to go the tall skinny route?
  3. Oct 22, 2023 at 5:48 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    I had 295 ATs before the 255s, and they were just heavy and never balanced super well on my 16x7" wheels. Wanted the diameter without more weight or balance problems, and it seems to have worked out well so far. I have about 20K miles on them with not too much wear probably thanks in part to 5-tire rotations.
    The 295s all full of peanut-butter-hill at Rush
    255s
  4. Oct 22, 2023 at 9:28 AM
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    I'm not sure I like the looks of the 255, but I'm sure I would get used to them.. I am getting a bit of rub on my UCA, and shock resi with my 285s. So maybe a narrower tire might help eliminate that. To maybe 255/80 geolanders is the way to go it'll save me about 10 lb per tire versus my STT pro so I would expect gas mileage to go up a bit too.
  5. Oct 23, 2023 at 7:07 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I can vouch for 255's. My 2017 Taco had 255/85R16 (33") Mastercraft Courser CXT's on it. They were excellent offroad, very tolerable on road on decently long commutes and trips, and I found the snow performance to be just fine. They also required zero lift or wheel changes to be rub-free on the body, only the mudflaps rubbed, which were a trim or removal away. I also got better gas mileage than the factory 265/70R16's due to the effectively increased gear ratio without much extra weight. I really like pizza cutter commercial terrain tires, they're usually E rated but the gains in traction are hard to ignore, and that set of CXT's balanced just fine. I am also a fan of narrow body rigs like the Aussies tend to build, so the width was just fine by me. I could also keep a fullsize spare under the bed without mods. I'd have bought those for this 4Runner if I could fit the spare under the body but the T4R has a smidge less room than the Taco so I settled for 32's while I build up the rest of the truck.
    JohnnyRed[QUOTED] likes this.
  6. Oct 23, 2023 at 11:46 AM
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Geolandar g003 in 255/80/17 are nearly impossible to find....but I just found a set and ordered them.
    Anyone need a 33" MT spare? I'll have 2 good Cooper STT Pro 285/70/r17 I'll sell you cheap. You can get all 4 if you want, but 1 is cupped bad due to balance beads that were in the tire, and the other has some light cupping (also from the beads).
    Also I have 1 full size spare but it's a mastercraft courser mxt, which is basically a STT Pro.
    Can take depth measurements if anyone is interested.
    rdpoe likes this.
  7. Oct 28, 2023 at 5:15 PM
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    good ole peanut butter hill. I’ve got a similar picture coming up that hill
  8. Oct 29, 2023 at 4:54 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    I did it in 2wd...
  9. Oct 30, 2023 at 4:45 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    that must be the key
    rdpoe likes this.
  10. Nov 1, 2023 at 12:43 PM
    willi573
    willi573 Member
    2009 Silver 2.7 Manual 4x4 Regular Cab
    Hello all,
    I am looking for a camper shell. Preferably silver match or black. Anyone looking to sell their camper shell, let me know. Cinci area.
    Thanks!
  11. Nov 7, 2023 at 2:05 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Looking for a hidden winch mount. Anyone have one? Or does anyone recommend against. Wanted a SSO hybrid tube bumper but that doesn’t look promising anymore.
  12. Nov 7, 2023 at 8:57 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Also posting this here as well for anyone interested:
    Posting this rifle for sale. It's been good to me, but I need to thin the herd and pay to pull my cat's teeth out. Thinking $1200 as it sits, zeroed at 200 with M193. Round count around or under 200 on everything but the optic, that's unknown history. Local to Indianapolis preferred but I can work out shipping to your FFL if necessary. Legalities are on you to figure out for your jurisdiction, I will not ask.
    Tip to butt:
    A2 Flash hider
    YHM 16" 7 Twist 5.56 NATO Dimple Fluted Barrel
    TLR9
    Dez Arms Set Screw Front Sight Post
    Midwest Industries 2-piece quad rail
    Magpul AFG
    no-name picatinny ladder covers
    Holosun HS503CU-GR, painted tan
    MaTech Buis
    PSA Nitride BCG
    Milspec charging handle
    Milspec Upper
    Aero M4E1 Lower
    LaRue MBT2S trigger, tuned with Skid Tactical ATAK trigger kit/Safety
    Magpul MOE-K2+ grip
    Griffin QD nut plate
    VLTOR A5 Buffer tube
    Sprinco Green Spring
    VLTOR A5 Buffer (I believe it's an A5H3 but I'm not 100%, I'll update tonight)
    Magpul MOE stock
    Viking Tactics VTAC sling
  13. Nov 7, 2023 at 9:40 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    That’s a super cool “Airsoft replica” you’ve got there
    Good luck with the legal transfer :anonymous:
  14. Nov 7, 2023 at 9:47 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    It's been a fantastic unit for me, so much so that I'm sad to see it go, it's just the 3rd AR and doesn't do anything the first two can't, while not doing stuff the other two can, so it must go.
    Caboose117[QUOTED] likes this.
  15. Nov 7, 2023 at 11:04 AM
    Summers_Kytaco_19
    Steven
    Independence, KY
    19 trd OR tacoma
    I’m sure you did buddy lol
    rdpoe[QUOTED] likes this.
  16. Nov 7, 2023 at 11:05 AM
    Summers_Kytaco_19
    Steven
    Independence, KY
    19 trd OR tacoma
    Dang man. I had one for sell for almost a year and someone finally bought it like 2 months ago!
    photodoc[QUOTED] likes this.
  17. Nov 7, 2023 at 1:11 PM
    Taco_badger
    Taco_badger Member
    Ashton
    2023 black Tacoma SR
    Going back to real simple
    I know it’s mostly a west thing, but anyone in here looking to do a Baja build/baja fenders? I’m postponing my build for a few years while attending college so I’m going back to stock
    I had plans of wrapping them so I just did a backyard paint job. Painted them black, and clear coated… but I’m not a body shop employee. One of the caps has dripping in the clear coat and a couple of blemishes throughout the paint. Either wrap them or probably look at repainting
    they’re from advanced fiberglass designs, and you can find all the info you need on their website. With the shipping and fender extensions, it comes out to over a thousand dollars. Im looking to trade for stock black fenders and a bumper, OR any other color plus $250 to help cover repaint costs.
    I will sell without trades for 700, but prefer to trade
  18. Nov 7, 2023 at 1:17 PM
    Taco_badger
    Taco_badger Member
    Ashton
    I’m also selling my:
    -MBRP catback exhaust ($200)
    -Bilstein 5100 lift kit with Icon AAL ($500)
    -SPC upper control arms ($300)
    if anyone’s interested
  19. Nov 7, 2023 at 6:14 PM
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Aw man. I think I saw that on marketplace and almost pulled the trigger then decided to just wait for the bumper.
  20. Nov 11, 2023 at 3:32 PM
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    Just a heads up, there is a used domestic cfx75 dual zone on sale at REI Rookwood. It's been sitting in the re-use section for like 2 months and is now 20% off that 880$ price, so 704$ for a 1200$ fridge.
    rdpoe and photodoc like this.
