Circles on my windshield won't go away
Discussion in 'Detailing' started by jethro, Aug 16, 2013.
  1. Aug 16, 2013 at 1:22 PM
    jethro
    jethro [OP] Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    So I have this really weird problem... When my windshield gets a little foggy (inside I think, like when the A/C is on) I can see a bunch of outlines of circles, like 4 or 5" in diameter? If I had to guess, the windshield was installed using robotic arms with vacuum disks- it looks like I am seeing the outline of these. I have cleaned the windshield with alcohol and vinegar and also bought a high end industrial glass cleaner and the glass gets super clean, perfect even. But then if there gets any fog on the inside of the windshield then I see the circles. WTF can I do about it- any ideas? Am I the only one?
  2. Aug 16, 2013 at 1:24 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    I don't have any suggestions for you, but I have it too.
  3. Aug 16, 2013 at 1:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had them when I first had my new windshield installed but Stoner's glass cleaner got rid of the circles for me.
  4. Aug 16, 2013 at 1:30 PM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    you are certainly not the only one, I don't know why the circles are so permanent, i've cleaned my windshield so many times, and have never been able to get rid of them. Cross we all have to bear
  5. Aug 16, 2013 at 1:39 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I have them too and i have cleaned my windshield several times and they won’t go away??
  6. Aug 16, 2013 at 1:40 PM
    TailDrag
    TailDrag Well-Known Member
    Rubbing alcohol? Clay bar?
  7. Aug 16, 2013 at 1:41 PM
    Pugga
    Massachusetts
    Put some muscle behind it. :cool:
    Stoners and a microfiber towel and mine were gone with 2 washes. The circles should be on the outside of the windshield, not the inside. There shouldn't have been suction cups on the inside but either way, same method for removal.
  8. Aug 16, 2013 at 1:46 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Is it condensation on the inside... the rings? If so it is from the a/c being on and set to defrost on the window.
  9. Aug 16, 2013 at 1:47 PM
    TacoSupreem
    Hayden
    Kentucky
    Wash about to use some steel wool! lmao
  10. Aug 16, 2013 at 1:47 PM
    TacoSupreem
    Hayden
    Kentucky
    Will try clay bar first
  11. Aug 16, 2013 at 1:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine has a handprint right in the driver's view like that. Cleaned the hell out it with no success. It only appears when the window fogs though.
  12. Aug 16, 2013 at 1:52 PM
    josepenajr
    josepenajr Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    haha i have those too have no clue what it is :/
  13. Aug 16, 2013 at 1:52 PM
    TailDrag
    If it is petroleum based it will be a bitch to get off, if you can even get it off.
  14. Aug 16, 2013 at 2:33 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    It's the cups when they install windshield. They come off after a few washings. But they are a pain!
  15. Aug 22, 2013 at 6:05 PM
    jethro
    Geoff
    Southern NH
    Wow, that's funny, I thought I'd have the only issue here. Guess I'll just keep trying to clean it. They should really find a way to not have that happen.
  16. Aug 22, 2013 at 11:47 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    My dads dodge has it too. It has to do with the way they put in the wind shields.
    I would just steel wool it like a boss.
  17. Aug 26, 2013 at 10:31 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Mine are going away next week I hope. Getting a new windshield put in due to a wonderful rock cracking it. My wife has it on hers too but froom the look it may come off
  18. Aug 26, 2013 at 11:02 AM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    I have them also, but only on the driverside corner. I assumed it was from a radar detector or a garmin. way to small to be from the factory installing the windshield.
  19. Sep 20, 2013 at 1:22 PM
    DavisBladeWorks
    DavisBladeWorks Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    Polish the glass....
    Glass can polish up just like paint, and it removes ALL of the little stuck on gunk and hidden smudges like that. You can order glass polish from chemical guys.
    In the mean time, use "invisible glass" and some steel wool. Spray the glass, rub vigorously with steel wool. After that, get a clay bar and go to town. Clean with invisible glass one more time.
  20. Oct 30, 2013 at 5:03 PM
    GWinstead
    GWinstead Well-Known Member
    Yep. My 2012 tacoma had the problem. I didn't know what it was until I read this thread. Regular glass cleaning over the past year did the trick. Wife just got a brand new Accord. And it's got the circles too.
