circuit board holding dash bulbs for heater controls
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrbowl300, Mar 24, 2015.
  1. Mar 24, 2015 at 1:38 PM
    mrbowl300
    mrbowl300 [OP] Active Member
    jack
    Scranton, Pa.
    SR5 EXT. Cab v-6
    Hey Guys:
    My stupidity, I was trying to change bulb for heater controls on dash and broke off a piece of circuit board, tried to repair it, no luck, I got it glued and stuck very good but now I don't have any lights for my three controls for heater. Any one know if those circuit boards can be repaired, if not anyone know where I can get one? 2002 Toyota Tacoma SR5 V-6 with air. I have all kinds of numbers of the unit itself, THANKS.
    mrbowl300
  2. Mar 24, 2015 at 1:41 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    the circuit board has delicate thin metal traces inside of it under the green coating sandwiched together, there is no repairing or reattaching it if it broke so you need a new one.
  3. Mar 24, 2015 at 1:57 PM
    mrbowl300
    jack
    Scranton, Pa.
    SR5 EXT. Cab v-6
    Keaker:
    Thanks for your help, I guess this item is a dealer item only right?
  4. Mar 24, 2015 at 4:50 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Call junk yards, look through craigslist and ebay before sucumbing to the stealership.
  5. Mar 24, 2015 at 4:56 PM
    keakar
    karl
    louisiana
  6. Mar 25, 2015 at 11:00 AM
    mrbowl300
    jack
    Scranton, Pa.
    SR5 EXT. Cab v-6
    hey guys I found one on eBay, all numbers seem to match an looks identical except for color of bulbs which is no biggy, only number that doesn't match is like a hand painted four letters on case of unit like done in white paint other then that numbers look the same, is there a place I can double check to make sure before i buy, thanks.
    mrbowl300
  7. Mar 25, 2015 at 11:59 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Does your's need two bulbs or three? I bought one from a guy on here that used two bulbs and my '01 had three bulbs. You're more than welcome to it for 15.00 shipped. I have no need for it.
  8. Mar 25, 2015 at 2:45 PM
    mrbowl300
    jack
    Scranton, Pa.
    SR5 EXT. Cab v-6
    wcp0611, thanks for the offer it needs three also. the one i found on eBay I'm buying looks exactly like mine, thanks again an have a great day.
    mrbowl300
  9. Mar 26, 2015 at 8:01 AM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    Mrbowl300--please post a follow up on how this works out. I need one too...
  10. Mar 29, 2015 at 6:17 AM
    mrbowl300
    jack
    Scranton, Pa.
    SR5 EXT. Cab v-6
    i will post soon as it gets here, they say on Tuesday, I'm hoping it works too, all the numbers look good and took a picture of there's and mine, look identical.
    mrbowl300
