Circuit Opening Relay issues?
Discussion in 'Technical Chat' started by AlastorK, May 13, 2024.
  1. May 14, 2024 at 10:13 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Me either. But I'm bad to start looking at step 17. When I could have found the issue at step 3. :rofl:
    10A EFI #2 fuse would be a check. It tells me the EFI relay is working, and that relay supplies power to a whole host of different "make it run" things.
    Still like to know if the tach is working while cranking.
  2. May 14, 2024 at 10:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Well the CEL is on so we know the PCM is probably online.
    TnShooter[QUOTED] likes this.
  3. May 14, 2024 at 10:32 AM
    TnShooter
    Deogee
    STOCK
    Yeah. We don’t have fuel or ignition one.
    And we won’t with out a crank signal. Which is why I ask about the Tach.
  4. May 23, 2024 at 4:44 AM
    AlastorK
    AlastorK [OP] Member
    Toyota Tacoma 2006 Pre Runner V6
    Update: Tried Cycling the key and the engine just abour starts but then stutters out.
    The fuses I have checked are not blown.
    I have used an advanced device and there are no codes.
  5. May 23, 2024 at 5:55 AM
    AlastorK
    The tachometer does not do anything while trying to start.
  6. May 23, 2024 at 10:56 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you check the fuses I listed above?
    Is your security light still flashing with the key in?
    Will your scan tool read data?
    If so see what the RPM is while cranking.
