Circuit Opening Relay Location???
Discussion in '1st Gen. Tacomas (1995-2004)' started by iveywt, Oct 25, 2014.
  1. May 6, 2025 at 9:01 PM
    #41
    mrlittlejohn
    mrlittlejohn Well-Known Member
    Michael
    Brunswick, GA
    95.5 Tacoma
    All original with 195K miles. Purchased some 22 years ago with an 18 year gap of ownership.
    Following...
    I am battling a similar problem on our 95.5 V6/4spd after the truck warms up. Crank and runs for 1-2 seconds and shuts off. I have located the COR, and have access to one from a friend soon. The truck is currently up on jack stands with the front end apart. Replacing the passenger side steering knuckle (bearing is shot), upper/lower ball joints, strut assemblies and a full power stop Z36 brake system. Once I get that done, I will be able to drive around to get to temp properly and maybe bypass the COR. Has anyone else done that? I am thinking pins 1-2 jumper will do that. I will do it while the COR is connected as I believe there are some other signal pass through.
  2. May 6, 2025 at 9:11 PM
    #42
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah buddy......me and you think alike.....
    .....but here''s the problem.....you get the ground from ecm....to close the circuit ....right
    what happens if you accidently send 12v back up that ground lead going back to ecm
    will that fry the ecm out
    or and if you bypass/sever that ground line permanently ...will that still keep the ecm happy and still do all the other crap it has to do
