ckeene9's '12 Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ckeene9, Jan 20, 2013.
  1. Jul 28, 2015 at 8:05 AM
    #2201
    ckeene9
    ckeene9 [OP] Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Haha don't worry, they'll eventually get too loud and on my nerves :anonymous:
  2. Jul 28, 2015 at 8:11 AM
    #2202
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    when the time comes... [​IMG]
    made the job of swapping balls out easy...didn't have to take the LCA off for the swap
  3. Jul 28, 2015 at 8:14 AM
    #2203
    ckeene9
    Chesterfield, VA
    See Build Thread
    Good deal, I ordered the TC cups too.
  4. Jul 28, 2015 at 8:22 AM
    #2204
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    some of those adapters are close, but i did the same...used the ball joint kit with the TC cups
  5. Jul 28, 2015 at 8:25 AM
    #2205
    ckeene9
    Chesterfield, VA
    See Build Thread
    Good to know. You think a large C-clamp will suffice with the cups?
  6. Jul 28, 2015 at 9:22 AM
    #2206
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Didn't you buy them new?
  7. Jul 28, 2015 at 9:45 AM
    #2207
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i couldn't find a C-Clamp that had an end that i could use with an impact and ratchet...
    i used an impact to get the old one out, then ratchet to slowly press in the new one...if it starts to get crooked, slowly press it back out...it'll straighten out before popping out all the way, then continue to press it in...
  8. Jul 28, 2015 at 9:45 AM
    #2208
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    it's only a matter of time before he has to replace the uniballs :D
  9. Jul 28, 2015 at 9:49 AM
    #2209
    2ndGenJonny
    Jon
    Gilbert, AZ
    I have about 20k on my balls. I'm not sure how to tell if they are worn
  10. Jul 28, 2015 at 9:56 AM
    #2210
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    excessive noise is the first indication...if you remove them from the spindle and grab onto them, they should be tight...if there is play in them, you should look into replacing them...
    with my camburgs, i had both go within 1 1/2 years and had one go on my TC LCAs go within a year (both cases ~35-40,000 miles)
    i was able to grab onto them with my hand and move them back and forth within the mount. the TC lower actually had some of the teflon come out on the bottom leaving a lot of room in there for play..
    Bsheriff11 likes this.
  11. Jul 28, 2015 at 10:06 AM
    #2211
    2ndGenJonny
    Jon
    Gilbert, AZ
    Good info! Thank you! I'm going to have the truck on a lift this weekend so I'll do an inspection
  12. Jul 28, 2015 at 10:20 AM
    #2212
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hey @ckeene9 I'll be doing my partial engine cage soon at DTF. About two weeks and a half from today! Keep your eyes peeled. I'll be posting pics after I get it done.
    ckeene9[OP] likes this.
  13. Jul 28, 2015 at 10:38 AM
    #2213
    2ndGenJonny
    Jon
    Gilbert, AZ
    I gave Pat from TC a call and he said the balls can go up to 50k depending on environment and use. He said exactly what you did on checking them as well. The rebuild kits aren't too expensive either. I'm going to take a look at mine since I'll have a coilovers off this weekend anyway.
  14. Jul 28, 2015 at 11:29 AM
    #2214
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    What?? Why am I not subbed here...
    Hi :wave:
  15. Jul 28, 2015 at 11:31 AM
    #2215
    2ndGenJonny
    Jon
    Gilbert, AZ
    Not enough t&a for you here mang. Sadly, its a build thread
    dakotasyota[QUOTED] likes this.
  16. Jul 28, 2015 at 11:32 AM
    #2216
    ckeene9
    Chesterfield, VA
    See Build Thread
    Sweet!
    :wave:
  17. Jul 28, 2015 at 11:52 AM
    #2217
    dakotasyota
    Dakota
    Ellensburg, WA
    Rats :pout:
  18. Jul 28, 2015 at 12:02 PM
    #2218
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I want to be included in the waving too! :wave:
  19. Jul 28, 2015 at 1:33 PM
    #2219
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    exactly...environment and use dependent...i put my equipment through a lot of dry desert UT backcountry and tend to see some water, mud and dry dirt roads in the CO backcountry...so mine are more likely to age faster...
    those on the east coast driving in the salty winter or on the beach a lot will also see faster aging most likely...
  20. Jul 28, 2015 at 1:37 PM
    #2220
    2ndGenJonny
    Jon
    Gilbert, AZ
    My buddy has had the +3 kit for 70k or more. Still hasn't changed his out
