Clacking noise on engine after oil change.
Discussion in 'New Members' started by dokkenks, Sep 9, 2013.
  1. Sep 9, 2013 at 5:41 PM
    dokkenks
    dokkenks [OP] Member
    Joel
    Cordova, TN
    TRD PreRunner
    Hey guys I' ve been a member for several months now but have not posted anything here. Great site by the way.... I have a question and I hope that someone could help me, i've changed my oil for the first time yesterday since i bought my 2012 taco, i used mobil 1 which i always use on my other car and ofcourse i also replaced the oil filter (fram) and air filter as well (fram). While driving today, i heard a clacking noise that seems to be coming from the engine, the noise comes and go or just everytime i accerelate. I wonder what is causing it? Should i be concern about it? Please help!
  2. Sep 9, 2013 at 5:46 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Is it like a ping/spray can rattle?
  3. Sep 9, 2013 at 6:05 PM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    Yes, it kinda sounds like that.
  4. Sep 9, 2013 at 7:24 PM
    User Name01
    Bolbi Stroganovsky
    It sound like the engine is "pinging". Mostly only older engines do this. This is usually associated with bad/cheap gas. Did you fill it up with a different gas by chance?
  5. Sep 9, 2013 at 7:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You're SURE its still got oil in it?
  6. Sep 10, 2013 at 11:54 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    i fill up gas at kroger location near me. i'm pretty sure the engine have oil in it.
  7. Sep 10, 2013 at 7:38 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    that's something you would want to be sure on :eek:
    I always use the Toyota oil filter on oil changes, there's a nice write up about filters on here.
    maybe take a vid to document the noise?
    and welcome to TW
  8. Sep 10, 2013 at 8:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Toyota filters are better than Fram (a roll of toilet paper is better than Fram) and they're only $4-$5 if you buy a box of 10.
    6 quarts, right?
  9. Sep 10, 2013 at 8:12 PM
    nj636
    Kev
    Jersey
    I load up when my dealership has the buy 2 get 2 free offer :D
  10. Sep 10, 2013 at 10:44 PM
    User Name01
    Bolbi Stroganovsky
    If it did not have oil, it would not have made it far at all, correct? And a cloud ou white smoke would hint to the seizing of the engine. Might just not have enough oil.
  11. Sep 11, 2013 at 5:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If everything is good in terms of .....Oil, etc.
    You're still under warranty - take it to the dealer. Better safe than sorry to have it 'on file' now if something worse develops later.
  12. Sep 11, 2013 at 9:07 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    I will change the oil filter to toyota brand and see what happens. thanks....
  13. Sep 11, 2013 at 9:09 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    I will try the toyota filter. I did 5.5 quarts as stated in the owners manual. should I put 6?
  14. Sep 11, 2013 at 9:10 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    I have put 5.5 quarts per owners manual instruction....
  15. Sep 11, 2013 at 9:11 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    Thanks Janster, I will bring my truck to the dealership if the noise persists.
  16. Sep 11, 2013 at 9:13 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If it's within the two dots of the dipstick then you're good. At first read I'm thinking the sound is the lifters. Check your oil level again.
  17. Sep 11, 2013 at 9:36 AM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    I checked the oil level again yesterday (several times) and it is in the middle of the two dotted lines:)
  18. Sep 11, 2013 at 11:46 AM
    Janster
    Jandy
    Lancaster, PA
    I highly doubt its the filter. I've used Frams on my Jeep for years. Unless the filter was 'faulty' from the factory and it exploded internally - its not the filter causing your noises.
    Do not put in 6..... That would be OVER filling.
    Overfilling can be almost as harmful as overfilling.
    If I'm reading everything correctly - You put 5.5 quarts in and the oil level is in the middle of the two dots?
    Are you on a level surface when reading the dipstick?
    If you have a 4.0L and put 5.5quarts in, that oil level should be at the top dot on the dipstick (on level ground). If its only at 1/2 way.....something doesn't sound right.
    Are you seeing any oil drips, puddles, residue on the underside of the truck? Any white smoke coming out the exhaust?
  19. Sep 11, 2013 at 1:23 PM
    dokkenks
    Joel
    Cordova, TN
    TRD PreRunner
    i just checked the oil level right now, its on the on the top dot. i would observe how it will run today going home and see what happens.
  20. Oct 10, 2013 at 1:25 PM
    brian
    Elizabeth City, NC
    Any update on this? Curious
