Clamshell
Discussion in 'Audio & Video' started by Xmplry808, Jan 4, 2021.
  1. Jan 4, 2021 at 1:20 AM
    Xmplry808
    Xmplry808 [OP] Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I had 2 subs in a spec sealed box in my previous car so I just cut the box in half and stuffed it in the rear of the cab. Didn’t sound good at all since the sub was angled forward, and I couldn’t recline my front seats, but I like the placement of the sub/box. Mounted the box using 6 existing holes in the cab.
    BDE7B7C4-CB85-4E60-9BCE-962122247A75.jpg D968834E-AA14-4F50-92B0-0987F5A1CEEB.jpg AFB5F07D-DC81-4320-A7E2-D6A170A3B7C1.jpg 069DDE11-1B0D-493B-B080-5C3B94B30A31.jpg 538C2AD3-209F-48B4-9CDA-423E109DFA49.jpg 12751A97-B6D4-4F68-885C-F91960F5CEA8.jpg5FAAFFB3-22B1-44DD-8058-160C59BD9194.jpg
    pinktaco808 likes this.
  2. Jan 12, 2021 at 3:15 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I don’t know man it probably sounds awesome but it kinda looks like dogshit
  3. Jan 13, 2021 at 7:35 AM
    badhabit2break
    badhabit2break Well-Known Member
    Stephen
    Houston, TX
    2018 Red Tacoma TRD Off-Road
    Stock
    first mistake was cutting the air space in half and thinking it was going to sound good.
    that install looks rough.
  4. Jan 27, 2021 at 10:09 PM
    Xmplry808
    Picture looks bad cause bad lighting but carpet is clean and smooth. Best part is how functional it is
  5. Jan 27, 2021 at 10:11 PM
    Xmplry808
    Just a bad picture with the bad lighting. The first box I cut in half that was 2 subs in a sealed spec box, so cutting the box in half using only one sub is still a spec box for one sub. But now I’m on a isobaric ported set up, custom box... hits lows! Gotta love the jl audio 13w6. The box was redone, the first isobaric box (pictured in the first post) was just to test to hear how it would sound before making it presentable (no pictures taken with good lighting). Everybody likes the exposed bolts makes it look beefier lol but I really like how it sounds and how functional it is with the space I used.
  6. Jan 27, 2021 at 10:39 PM
    Xmplry808
    Just went out in the rain to take a picture. Still in the dark but I do have LED lights now so it’s a little better lol. I like it too that it’s different from anyone else.C36147D8-00DF-4F9B-BC9D-A8809DCCA612.jpg
    sorry can’t see the sides of the box but it’s super smooth now. This post was just to show a different style of system that we could do in our trucks. Sorry if my install is not to your liking.
  7. Jan 28, 2021 at 6:55 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Well like I said I’m sure it sounds good and makes some serious low bass but it looks like you got Snoopy‘s doghouse in your back seat. The install is clean I just don’t like the look of the box itself then the speaker is up past the window so it’s going to block visibility and invite someone to break into your truck. Sorry if it sounded like I was talking down to your skills that wasn’t the case at all I just don’t like it but it’s only an opinion I’m sure lots of other people will be into it.
  8. Jan 29, 2021 at 12:48 AM
    Xmplry808
    thanks you for your opinion. As for it looking like a dog house, with the angles this box has, it looks pretty trippy in a good way, it catches your attention. But being a bass head I am and already having these speakers I would say this was the best practical way to use them. As for visibility it doesn’t block much view since I have a tailgate spoiler that is blocking more of the view and I do have a rear camera so it’s not an issue. Having unwanted attention is an issue though the only issue. My brother and cousin got their cars stolen, in those cases I learned not to blast your music before you park in public and always use your alarm lol. And I again I like to be different maybe not for everyone and their goals but it met my goals.
  9. Jan 29, 2021 at 4:39 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Yeah man I get that. Sometimes I come off as a dick unintentionally when trying to express an opinion so sorry if that’s the case here And I’m sure it puts out some serious bass
  10. Jan 29, 2021 at 10:39 AM
    Xmplry808
    No worries bro I just wanted to explain why I had to create this box the way it is. If I didn’t have those speakers to begin with, I would’ve used a smaller speaker that’ll make the box narrower which would be more practical. I mean who the heck would put a 13.5” speaker in a access cab that still wants to use the rear seats but I think it turned out well. Lol
    If you don’t mind me asking do you have a system? Or plan too? If you do how would you want your system be?
  11. Jan 29, 2021 at 12:03 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I’ve been working on little bit at a time for awhile. I also have an access cab so most likely I’m going to loose the rear at some point. I have hertz 6.5s in all the doors and a 8 inch sub to add some bass while I continue to save for the next part. Next up is crimping tools so I can make all the cables I need after that I can finally get my alternator from sdhq it will give me 270 amps with about 170 at idle I think. After that comes the battery not sure if I need to add a second or if I can get away with one. Then I should be able to power a good size amp to push a couple 12s shooting for around 1500 rms or so. The doors are amplified now so my mids are pretty loud so I think I’m good there. All this started because my daughter was shit talking my stock system and told me her moms x system was way louder then mine and that simply will not do. I figure probably 18 months or so and I should have it done if nothing unexpected comes up and yes I know I have problems but I don’t care. I’ll try not to make shithead comments in the future but sometimes for reasons I don’t understand I’m just an asshole lol.
  12. Jan 29, 2021 at 12:16 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    How much power are you giving that big bastard?
  13. Jan 29, 2021 at 1:28 PM
    Xmplry808
    it’s all good bro you had valid statements, in the picture the visibility does look bad. So I wanted to check your concerns lol
    The box does look beastly in person so I could see why you say it’s a dog house lol I wanted gray carpet but audio shop didn’t have on hand.
    B6FEF027-5E36-49F1-B494-3948A13003DE.jpgbut yeah you can see my tailgate spoiler/head rest blocks more. As for the magnet it doesn’t block an important view. The only time I use the rear view mirror is to check if there’s a cop behind me lol. Since my windows are tinted the speakers isn’t obvious either, but I do like the cool factor of seeing the magnet lol.
    if you plan to lose your rears down the road you will have more options for a set up. My wife would never let me take the whole rear. I did see some people put the box onto one side, only taking one seat, but I personally don’t like the look of that.
    I have a JL audio 1000/1v2 amp feeding the two 13w6v2
  14. Jan 29, 2021 at 6:48 PM
    Xmplry808
    The only thing is I can’t lift up the bottom of the chair so I have no access to the storage space beneath. I don’t have anything in there but would be nice to be able to open it.
    This set up is air hungry though! For example blasting it with the windows up sucks, even if I have one window fully open. Right when I drop the other window you can significantly hear it and feel it get louder. But the system can even get a bit louder when the doors are open and that’s only when we are tail gating lol. Wish on the access cab the rear windows can go down.
  15. Jan 30, 2021 at 6:45 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Lol it’s a beast. Did you have to do anything to your electrical system to power it? I’m curious how many watts the stock set up will support. You have to upgrade to run something that size right?
  16. Jan 30, 2021 at 8:51 AM
    Xmplry808
    I have the big 3 upgrade and AGM battery. Lights do dim, so I installed LED’s for less wattage consumption but still has “good” output. That’s why I didn’t do the famous UHU. I was looking into getting an higher output alternator but for now so far so good lol and this is also supporting my other JL 300/4 amp. The amps I have delivers full power at any voltage between 11 and 14.4 volts with JL Audio R.I.P.S technology.
    Do you have any particular speaker you want to use? Not sure what your daughters mom has but yea you gotta show them what a real system sounds like lol
  17. Jan 31, 2021 at 9:24 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Originally I was thinking a couple Rockford Fosgates would probably do it. I’m pretty impressed with the 8w3v3 so I might stay with JL. I mean it’s small and in a super shallow box but does a good job for what it is.
    Xmplry808[OP] likes this.
  18. Feb 1, 2021 at 10:06 PM
    Xmplry808
    Rockfords are nice, but yeah I really like JL audio products for SQ.
    i got a funny story to share. The owners cousin of a sound shop was prompting RF all the way, since RF rep just came. He had RF everything in his 4runner so we did a sound comp with my JL audio system and everybody that was there, picked my car for best balance of loudness and clarity. My 2 13w6 in a sealed box, it would flex my windshield. It rattled my gas cap cover off, had to weld it back on lol. 2 weeks after I went back to the sound shop and the guy has JL everything and better models than mine lol I’ll never forget that though.
    you could add another 8” and still would fit in the middle as another good option.
  19. Feb 2, 2021 at 10:00 PM
    silvertacoma05
    silvertacoma05 Well-Known Member
    Jacob
    Knoxville, TN
    Silver 05 PreRunner, Long Bed, 4 Door
    3” toytec lift, JBA Offroad UCA, fuel wheels, bfg Ko2’s, 2 JL10W3V3's, JX1000/1D, Image Dynamics Component door speakers, Taco Tunes 4 channel amp (100 watts per channel) Baja Designs Squadron Pro, Spyder Auto Headlight Housing
    i went ahead and ditched the passenger rear and middle seats in my 2nd gen double cab and built a custom ported box for my 2 JL 10w3’s and it is louder and cleaner that most systems that I’ve heard. I love JL’s products and I would like to look into a W7 but they are so pricey...
  20. Feb 3, 2021 at 5:23 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I’ve spent the last couple evenings looking into the jl series. Looks like the one you are running is becoming harder to find unfortunately. I want one of 13w7ae,s in the worst way but I think the price will probably keep me out of that one. Having two of those I bet you could have rattled shit in the house from your driveway lol.
