Clamshell
Discussion in 'Audio & Video' started by Xmplry808, Jan 4, 2021.
  1. Feb 3, 2021 at 8:50 AM
    Xmplry808
    Xmplry808 [OP] Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    Got a pic of your set up? Yea I’ve tried other brands and heard a lot of brands. I ended up going back to JL audio, very efficient and quality products. W7 is just a beast. The problem with W7 for my applications in my cars I had, was air space and just the size of that speaker. But the w6 line has been perfect for multiple applications I had to deal with.
  2. Feb 3, 2021 at 9:03 AM
    Xmplry808
    I just thought it was funny how the shop was promoting a brand that I had in the past and know how JL compared, which they sell but wasn’t promoting it. That’s why I didn’t mind testing our set ups. At the end he blamed his EQ tune lol. Yea the more reason I like my subs is the rarity of having a 13, I had these subs for overs 8 years and I had to redo the surrounds once and it’s still going strong. W7 is a beast! But the new 12w6v3 is a great sub, and cheaper. My cousin picked up one and for one sub it sounds clean, gets down and loud. Ive tried lots of different brands all in which has is positives of costs and loudness, but I went back to JL audio at the end.
  3. Feb 5, 2021 at 12:09 AM
    silvertacoma05
    silvertacoma05 Well-Known Member
    Jacob
    Knoxville, TN
    Silver 05 PreRunner, Long Bed, 4 Door
    3” toytec lift, JBA Offroad UCA, fuel wheels, bfg Ko2’s, 2 JL10W3V3's, JX1000/1D, Image Dynamics Component door speakers, Taco Tunes 4 channel amp (100 watts per channel) Baja Designs Squadron Pro, Spyder Auto Headlight Housing
    I’ll take a picture tomorrow and throw it up on here. It honestly was worth ditching the back seats to be able to build the box to the proper airspace. Previously I built a box to fit behind the back seats. Had to modify everything to fit it and it was constantly having vibrations and air leaks.
    Xmplry808[QUOTED][OP] likes this.
  4. Feb 5, 2021 at 12:24 AM
    Xmplry808
    Oh man I gotta see it lol. No matter how good jl audio subs are, the box is everything for any speaker. For us bass heads would do anything for it lol
