Clanging sound at wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by Inverno4, Jun 26, 2013.
  1. Jun 26, 2013 at 4:11 AM
    Inverno4
    Inverno4 [OP] Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    I've replaced the upper and lower ball joints, coilovers, inner and outer tie rods, swaybar endlinks but when I go over bumps, it still sounds like there is a "clanging" almost like pots and pans banging together. I've even bent out the dust shield to no avail. Is there any chance its a bushing for the UCA or LCA? Wheel bearing loose? I'm at a loss. Its only on the driver's side and nothing seems to be loose on external parts.
  2. Jun 26, 2013 at 4:17 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I would get under there and have someone bounce the bumper up and down to try and see/hear what is going on. Also use your hand to bang on all the shields you see. It sounds like it will be a light metal noise not a heavy item based on your pots and pans description
