Clank/Rattle sound from rear passenger side suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alexc, Oct 15, 2013.
  1. Oct 15, 2013 at 7:18 AM
    alexc
    alexc [OP] Well-Known Member
    Alex
    Tampa, FL
    I bought a used 07 AC off road 4x4 a few months ago.
    Whenever I got over enough of a speed bump/off a curb/ whatever it may be a hear a clanking sound from the rear passenger side. Also under heavy acceleration I hear somewhat of a rattleing sound and when I go in reverse and stop rather quick I hear a clank type sound as well.
    I havn't put it on a lift yet to take a look at it but from what I can see so far there is nothing noticiable and the shop that put tires on not too long ago didn't see anything obvious either.
    The rear springs do not have the TSB but does have helper springs that the previous owner had put on. Maybe they need to be tighened?
    Any help is greatly appreciated.
    Alex
  2. Oct 16, 2013 at 5:43 AM
    alexc
    Alex
    Tampa, FL
    any ideas?
  3. Oct 16, 2013 at 5:47 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Probably rear driveshaft u-joint (at diff) and/or center bearing.
  4. Oct 16, 2013 at 6:03 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    mine was doing the same. broken leaf spring.
    dealer will ask over $800 to replace.
    my mechanic replaced for $300. (found a used spring set). working great
  5. Oct 16, 2013 at 6:17 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I have a clunk/thud in my 2009 coming from both sides of the truck i've been trying to figure it out for a month now.It does it over light bumps and sometimes going slow around corners.I think mine is coming from the front leaf spring mounts. I can see the front part of the leaf moves left to right if I have someone shake the truck hard left to right.( I forgot to mention that i have aftermarket leaf packs.) I think the leaf pack is a little narrower than the stock ones. I've tightened the bolts as tight as i can but it still does it i might try to put a washer in between the spring and the bracket to take up the gap.
