"clank" sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nepil, Jan 13, 2011.
  1. Jan 13, 2011 at 4:11 AM
    Nepil
    Nepil [OP] BEACH BUGGY
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    I was backing out of my driveway last night. When I shifted from reverse to drive, I heard a loud clank. I have a 1999 4 cyl. 4x4 automatic. I tried going from park to reverse- no sound. Drive to reverse- no sound. Only get the clank when shifting from reverse to drive. I will be the first to admit that Im not a mechanic. Tacoma world please help diagnose my problem! Thanks in advance!
  2. Jan 13, 2011 at 4:44 AM
    Nepil
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    Help?
  3. Jan 13, 2011 at 9:21 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Check the universal joints.
  4. Jan 13, 2011 at 10:24 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    check transmission fluid
  5. Jan 13, 2011 at 12:40 PM
    Nepil
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    Thanks for your input guys. Transmission fluid looks good. I took it out for a test drive (didnt hear the clank) Everything seemed ok to start with, but when I started slowing down from about 45mph with no braking I felt a slight vibration. Drove straight home. Put it in reverse then drive-CLUNK! I think that I have a driveshaft/u joint/bearing problem. Nothing feels loose under the truck. Not sure how to test u joints
  6. Jan 13, 2011 at 12:42 PM
    Nepil
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    any suggestions?
  7. Jan 13, 2011 at 12:51 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    How long has it been since the drive line zerks got greased?
  8. Jan 13, 2011 at 12:56 PM
    Nepil
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    I feel like an idiot, but ive never done it. what are driveline zerks?
