Clank when shifting to Drive from reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Dec 21, 2011.
  1. Dec 21, 2011 at 7:55 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    UPDATE
    I finally figured it out. It was indeed the brake pads shifting.
    I figured it out after letting the truck roll slightly down hill.
    I put the truck in neutral let the truck roll forward a little pressed the brake.
    I could hear the cluck but not near as pronounced.
    Then shift to drive an NO clunk.
    Glad it wasn't the transmission.
    I have a 07' Tacoma V6 TRD-Off Road.
    When switching from Reverse to Drive there is a "clunck" sound. The sound is
    is more prevalent when on a downward slope.
    To be honest I have NOT herd it do it on level or an upward slope ground.
    The sound seems to be coming from the front of the truck but I not positive.
    I did find that after it "clunks" and you are pressing the brake (Truck has not moved)
    then switch back to reverse and then Drive again, it will NOT make the "clunk".
    But if you drive an short distance in reverse (couple feet) and then switch to Drive the "clunk" sound comes back?
    Anyone else have this sound or know what it might be? :confused:
    TallguyNaTrd33 likes this.
  2. Dec 21, 2011 at 9:15 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    I park on a slope every night. I have heard a hard sound a couple times like its a hard shift into the reverse gear. I don't know exactly what it is, but your not the only one.
  3. Dec 21, 2011 at 9:26 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Next time you roll down to a stop on an incline or wherever it is that it clucks at, before taking your foot off the brake set your parking brake then the next time you get in to go somewhere press and hold the brake before putting it in gear. If it doesn't do it then it's just the gears being misaligned and banging together to line up. My first truck was a 5-speed which if parked on an incline in gear only then it would pop out and roll so I'm in the habit of setting it even on my automatic taco.
  4. Dec 21, 2011 at 9:31 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    How long has it been since you greased the drive-line zerks?
  5. Dec 21, 2011 at 10:24 PM
    TnShooter
    Deogee
    STOCK
    Mine is an Automatic Transmission.
    I ALL WAYS use the E-Brake, it's VERY rare I forget to us it.
    It has been a habits since I had my first Manual Transmission.
    I thinking it is the drive-shaft or U-joint switching direction.
    uhh, 16 months ago?
    Maybe not even then, I assume that Toyota did this before I bought it.
    But it was used when I bought it.
    It very well could never have been greased since it was new?
    I was under the impression the drive line was sealed.
    My PreRunner had no Zerk fittings and I even called Toyota to verify it.
    They told me the every thing was a sealed unit under the truck.
    I guess, in all honesty, I really should climb under there and look?
    Anyone know where the grease fittings are under the 4x4 Trucks?
    I know it took me a a friend 20 mins to find them on a Dodge 2500HO.
    There were cover in grime and in an awkward spot to find.
  6. Dec 21, 2011 at 10:29 PM
    Warhorseforever
    Will
    Sand Lapper
    wtf at the quoted names? And greasing should be your fist swipe at this problem. Just crawl under and feel around as I'm not really sure where they are at.
  7. Dec 21, 2011 at 10:59 PM
    TnShooter
    Deogee
    STOCK
    When I quote someone, it makes it easier for others to read.
    Other wise they have to scroll back up to figure out what
    question I'm answering. You can think of it as forum etiquette.
    As for the Grease fittings, there are NO fittings on the 2wd trucks.
    There should be 5 on the 4x4 models.
    As usual, I get what I deserve for assuming the 4x4 had none like my 2005 PreRunner.
  8. Dec 21, 2011 at 11:03 PM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    I had this issue too...replaced u joints with greasable ones and it's gone. if it's something else, atleast your u-joints will be greasable..
  9. Dec 21, 2011 at 11:04 PM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    He knows that, but you quoted something he didn't say...someone else did...computer derped.
  10. Dec 21, 2011 at 11:09 PM
    TnShooter
    Deogee
    STOCK
    I didn't notice that....
    No idea what is going on there?
  11. Dec 22, 2011 at 5:55 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The front drive shaft's zerks are on the center of the u-joint's cross. The rear shaft's zerks are on the cap end of the u-joint. With xfer case in 2wd, rear on jack stands, and trans in neutral, both drive shafts will spin freely and are easily greased.
    Check your ujoints for rotational slop and check the differentials for the same. If there is any slop in the u-joints, replace them. Have the diff serviced if there is excessive slop(a small amount is normal). If there isn't any excessive slop, the noise is normal. There will be some noise when the drivetrain switches direction and all of the normal gear backlash and driveline slop is taken up.
  12. Dec 22, 2011 at 6:01 AM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    I was told by the stealership it was the breaks that make the clank. Has anyone reported the problem and been told different?
  13. Dec 22, 2011 at 6:04 AM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    thinking back...I had a clunk/pop when changing to D from R and straightening the wheels...then I had the u joint clunk..brake pads and u joints were replaced the same day and now all pops/clunks are gone...except a hmmmm noise, but thats a different story...
  14. Dec 22, 2011 at 7:05 AM
    TnShooter
    Deogee
    STOCK
    According to all my research this is most likely the problem.
    Apparently it is the bake pads shifting directions in the caliper.
    I think Toyotoa has a TBS on it. TSB# BR0005-07.
    I can't find the whole TSB on BR00075-07. It would be nice to know if they have any ideas on fixing it.
    I'm going to try and apply the E-Brake before shift to drive to she if this helps any. It should at least make it a bit quieter if it is the brakes.
    I haven't yet climbed under there yet it been raining here and the ground is wet. It's supposed to rain today also, maybe this weekend it will dry out enough for me to get under there and figure this out.
  15. Dec 23, 2011 at 6:52 AM
    Major91
    Masshole
    I'm pretty sure the TSB your talking about is a different issue. I am pretty sure this problem of the clunk is the breaks and Toyota reps have said its normal.
    brake pads shifting in the calipers
  16. Jan 9, 2012 at 1:12 PM
    TnShooter
    Deogee
    STOCK
    That was the problem. It's still doing it.
    I'm not going to replace the pads as there is plenty life left in them.
  17. Jan 9, 2012 at 1:21 PM
    Major91
    Masshole
    Join the family! LOL :D
  18. Jan 9, 2012 at 1:26 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    mine does the same thing it seems to clunk louder when the truck is cold or the ac is on.
