Clanking noise from front brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smcgill, Jul 28, 2009.
  1. Jul 28, 2009 at 9:17 AM
    smcgill
    smcgill [OP] Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    2008 tacoma double cab sr5 with a Curtis Home-Pro 3000 snow plow
    Any one here have that clanking noise coming from the front brake pads. :annoyed: The pads move back and forth on the two pins. The round holes that the pins pass threw are now elongated , causing the pads to shift in the direction your going and when they stop " CLANK". Just asking. :goingcrazy: Sean
  2. Jul 28, 2009 at 9:20 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    They make a grease/ lithium soap to put on the back of the pads that might help. It's really inexpensive. You would usually put it on when installing new brakes, but taking them apart and adding some might help.
  3. Jul 28, 2009 at 9:25 AM
    smcgill
    Sean
    Nope!! that would be diff. noise!
  4. Jul 28, 2009 at 9:35 AM
    drew02a
    San Antonio, TX
    Not necessarily. There have been other posts about the same noise. Give it the old search-aroo!
  5. Jul 28, 2009 at 9:37 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I have the same issue, smcgill. It's a clunk sound when braking. It's definetly loose pads hitting against the caliper. Glad I'm not the only one. Here is a sound clip I took. So how do we fix it???
    http://www.youtube.com/watch?v=0BO-Zk56XoQ
  6. Jul 28, 2009 at 9:41 AM
    smcgill
    Sean
    Well when the pads are ready to be replaced because of wear , I'll go aftermarket! Maybe the metal will be stronger & not wear or elongate the holes! It's funny that Toyota will not ac·knowl·edge this problem on the Tacoma's , but did say some of the cars ,it's known! Sean
  7. Jul 28, 2009 at 9:47 AM
    drew02a
    San Antonio, TX
  8. Jul 28, 2009 at 9:48 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    so replace the pads.
  9. Jul 28, 2009 at 9:51 AM
    drew02a
    San Antonio, TX
    If the pads are moving around, it might be that the pins have worn or that there is a design flaw. Replacing them likely won't help.
  10. Jul 28, 2009 at 9:55 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Mine have been doing it since day one. Its not quite like in that video, its just a single clank once they are actuated. Either way, I never really worried about it, since it was that way since day one.
