Clanking noise from front end normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DiffLock, Sep 25, 2017.
  1. Sep 25, 2017 at 7:26 AM
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I've got a '17 TRD OR 4x4 manual. When the bumps get rough, I hear a clanking noise from the front end. This has always happened, even with the stock suspension. Is this common/normal? Anything specific I should torque down?
  2. Sep 25, 2017 at 7:59 AM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    How many miles? Has it done it since new?
    Have you checked your front body mounts? They're known to fail quickly and make those kind of noises.
  3. Sep 25, 2017 at 8:19 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    4k miles, has always been this way.
  4. Oct 3, 2017 at 7:23 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Looking in to possibly brake pads rattling. I read you can use disc brake quiet glue to silence the chatter.
  5. Oct 3, 2017 at 7:45 AM
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    I have the same and after various videos and posts, I conclude it's the disk pads and completely harmless.
    NickleCityTaco likes this.
  6. Oct 3, 2017 at 10:32 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    This noise?
    Leathermatt likes this.
  7. Oct 3, 2017 at 10:33 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Yep, sounds like it. What is it... brake pads?
  8. Oct 3, 2017 at 10:33 AM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
    I get this same thing every morning going over the speed bumps to get out of my neighborhood.
  9. Oct 3, 2017 at 10:35 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    I'm still unsure. Trying to get the dealer to figure it out still. A friend of mine thinks its the rack and pinion making noise.
    Found this video on the forum somewhere to show the dealer. They pretty much told me that unless they can hear it from my truck they can't do anything.. But I can't make it do it on command so I'm sorta stuck in the middle at this point.
  10. Oct 3, 2017 at 10:35 AM
    Hills89
    Hills89 Well-Known Member
    Tyler
    16' dcsb off road manual 01' excab Trd manual
    Lifts and stuff
    I have this noise as well.
    frymy14 likes this.
  11. Oct 3, 2017 at 10:36 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    Yep, And it doesn't happen over every bump either so its hard to re create for the dealer.
  12. Oct 3, 2017 at 10:37 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    When offroad with a lot of bumps it gets really annoying.
  13. Oct 3, 2017 at 10:38 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    I haven't really wheeled my truck and the first thing the dealer told me was because of the mud under my truck getting stuck in components. Jokes on them, I've never taken it in the mud. Its just dirt from Forest service roads..
    helix66 likes this.
  14. Oct 3, 2017 at 11:38 AM
    abreunig
    abreunig Member
    Andrew
    2016 Toyota Tacoma TRD Sport 4x4 DCSB
    I have the same noise. Doesn't always make the noise and sometimes its worse than others.
  15. Oct 3, 2017 at 2:04 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I will apply the disc brake glue and report back if it helps!
    Stuffs likes this.
  16. Oct 3, 2017 at 2:11 PM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I get this too from time to time backing out of my drive way. It doesn't happen all of the time and sometimes it lasts for a little while then goes away. I have upgraded my radiator mounts to poly ones and still does it but not as bad. I need ot get under there and retorque them though.
  17. Oct 3, 2017 at 2:32 PM
    Stuffs
    Stuffs Active Member
    could it be the springs hitting each other when it compresses?
  18. Oct 3, 2017 at 2:33 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    doesn't seem like it to me. I've had two different suspensions and the noise didn't change.
  19. Oct 3, 2017 at 2:35 PM
    Stuffs
    Ok, in that case, def try adding some brake quiet to the pads to see.
  20. Oct 3, 2017 at 5:12 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    will do.
