Clarion Equalizer/Line Out Converter/Driver : Portland, OR
Discussion in 'Buy / Sell / Trade - Other' started by elduder, Feb 19, 2019.
  1. Feb 19, 2019 at 7:35 PM
    elduder
    elduder [OP] Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    I recently replaced my OEM head unit and no longer need this. Nothing wrong with it, works as expected.
    This equalizer allows you to more finely tune the sound from your factory radio, it worked very well in my truck and definitely evened out the sound.
    This can be installed on a totally stock system but I would only recommend it to anyone looking to add an amp or sub. It can produce a 8v RCA out put so it works as a line driver as well as converter since it will convert speaker level to RCA low level. Works just like the popular LC2i (which I had prior to this) and allows you to wire the speaker wires into it then get RCA outputs for front and rear as well as a sub. I can detail this more clearly for anyone interested but the short of it is, if your adding an amp and sub and keeping the head unit stock you need this or something like the LC2i. This gives you the additional ability to tune the sound frequencies unlike the LC2i though.
    Everything needed is included except the factory box. I will also include some remote turn on wire, ground wire and a fused power wire.
    Located in Portland OR area.
    $40 Picked up
    $55 Shipped in the lower 48
  2. Feb 25, 2019 at 6:07 PM
    elduder
    Van WA
    ^^^^^^^^^^Bump^^^^^^^^^^^^^^
  3. Mar 5, 2019 at 9:07 PM
    elduder
    Van WA
