Clay bar Steps please.
Discussion in 'Detailing' started by pinktaco808, Nov 12, 2012.
  1. Nov 12, 2012 at 10:55 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    What the detailed steps for clay bar a vheilce thankyou.
    1.Wash
    Clay
    Wash
    Wax
    2. wash
    clay
    wax
  2. Nov 12, 2012 at 10:56 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    wash
    clay
    polish
    wax
  3. Nov 12, 2012 at 11:01 PM
    TacoCBR
    TacoCBR Well-Known Member
    Irvine, CA
    13 Tacoma DCLB 4x4 TRD
    Wash. Don't dry.
    Use quick detailer along with the left over water as lubricant for the clay process.
    Step 2 wax.
    Step 3 wax/carnuba
    I use Mother's on all my vehicles. Can't go wrong.
  4. Nov 13, 2012 at 6:07 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    x2, although you can skip the polish step if you have a light color or don't care about the fine scratches the clay leaves.
  5. Nov 13, 2012 at 6:10 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    subed to come back to
  6. Nov 13, 2012 at 7:23 AM
    pinktaco808
    thanks everyone
  7. Nov 13, 2012 at 9:35 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'm surprised at everyone suggesting to go right to wax or polish after claying. I would suggest a quick re-wash to remove the clay lube. Only takes an extra 10 minutes
  8. Nov 13, 2012 at 11:19 AM
    pinktaco808
    that what i was thinking so what the proper way do you rewash with like how you normally wash your car or do you just wash it down with water.
    How long you guys guess it take for the whole process?
  9. Nov 13, 2012 at 11:26 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I don't think a complete re-wash is necessary since obviously a rinse and dry before polish would be involved which removes any lubricant used but I can see what you a referring to if you are worried the lubricant would leave any residual that a polish wouldn't remove.
    Dish soap in water works as a clay bar lubricant as well. If I am going to do a complete wash clay polish wax I use dish soap to wash and use dish soap and water to lubricate the clay bar.
  10. Nov 13, 2012 at 11:59 AM
    Gooch
    Orange County CA
    I use quick detailer as my clay lube which in many cases is what I clean my truck with (when it doesn't rain).
    As I clay I wipe the panels dry with a clean microfiber so they are perfectly clean when I'm done. If they start to dry during the process, I use a little more detailer.
    I agree that if there is anything left on the surface it should be cleaned before waxing. I had my process stuck in my head but realize that's not how everyone does it!
  11. Nov 14, 2012 at 5:52 AM
    pinktaco808
    when you clay do you use half the bar for the top and the other for the bottom or just one piece. Also some comes with 2 so save for another car?
  12. Nov 14, 2012 at 6:13 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Use auto wash soap NOT dish soap. You do not want to use dish soap on your paint.
  13. Nov 14, 2012 at 10:26 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Depending on the size of the bar, I typically tear it in half. Each time you do a section (1x1', 2x2', whatever), you'll want to roll and knead the clay to keep as clean of a section as possible. Like anything that touches the paint, you ideally want the least amount of contaminents as possible to touch the surface.
    Not so much the paint as it is the mouldings and trim.
  14. Nov 14, 2012 at 10:31 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Depends how proficient you are at detailing. The more you do it, the quicker it generally becomes b/c you're more familiar w/ the product you're using and you develop a routine.
    Time...well...that all depends. How bad is the vehicle? I can do a new car faster than a 15 year old daily driver that's never seen a coat of wax. Last step product? Opti-Seal is significantly faster than using something like...476.
    Yea, all I'm saying is that the vehicle should be rinsed/washed/whatever before moving on to the next step. Reduces the chance of any "oh shit" moments :)
  15. Nov 14, 2012 at 12:05 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I also say wash after claying/polishing. At the minimum an iso alcohol wipe down. Check out autopia.org
  16. Nov 18, 2012 at 2:11 PM
    dessertsand05
    dessertsand05 Well-Known Member
    Boston
    05 Tacoma DC SR5 4x4
    Working on it
    So what are you accomplishing by the second wash?
    Doesn't extra wax get removed when you apply and remove the polish wax?
    So if you follow the ask a detailer sticky, you would....
    Wash (dont dry off if you clay bar, right?)
    Clay with quick detailer, rub off after?
    Wash again and then towel dry
    Polish (colorX)
    Seal
    When in this process would you use the scratchX on the trouble spots?
    I have been following the ask a detailer process for two years now, but starting to think claying the truck 2-3 times a year isnt doing much anymore as the paint is kept in shape. Just wondering how many of theses steps are redundant and not always needed, all the various waxes I use say they do the same thing on the bottle. Am I just apply 3 coats of similar waxes on the same day?
    Would like to understand more of whats going on with all these steps. Truck does come out amazing :)
  17. Nov 18, 2012 at 5:00 PM
    conquistador
    conquistador Well-Known Member
    Tulsa, OK
    88 4Runner
    Checkout this site http://www.detailedimage.com/Auto-Detailing-Guide/
    This my go to on detailing tips, techniques, and supplies
