Clay Bar?
Discussion in 'Detailing' started by Waverly, Nov 10, 2010.
  1. Nov 10, 2010 at 11:54 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Give it a try, it works wonders.
  2. Nov 10, 2010 at 11:56 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I will, so your supposed to wax afterwards?
  3. Nov 10, 2010 at 11:57 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I would just to do the whole detailing while your at it.
  4. Nov 11, 2010 at 12:05 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    I havent done any REAL detailing so i think im long overdue.
  5. Nov 11, 2010 at 12:08 AM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    It is worth it. Set aside a few hours and a cooler with beers.
  6. Nov 11, 2010 at 12:11 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    That sounds like a plan, i havent seen my truck in 3 months,ill be home next week. So some quality time with beer and my truck will be much over due!
  7. Nov 11, 2010 at 12:21 AM
    yotaman3130
    yotaman3130 Well-Known Member
    Ms
    08 TRD Offroad
    Kobalt low profile tool box, Toyota Roof Rack, K&N drop in air filter, Blue sea fuse panel, Streamlight mounted in glove box, NFAB step bars, FJ offrad rims
    wash, dry, clay, polish, wax.
    clay bar takes away all impurities from the paint, small dirt and other particles that are in the clear coat and it cleans dirt and particles out of small scratches. not worth the time if you dont care (obviously). but if you are detailing it is a must and shocking difference. dont do it every time you wash tho, unless you are gonna polish/wax because it will remove your coat of wax. and yes it removes overspray as well :)
    also, there are different grades of it, just like different sand paper grits. if you dont see results, then you might have a weak grade.
    I own a small mobile detailing biz and do full details out of my garage at home, i know this stuff and its great tool when detailing
  8. Nov 11, 2010 at 4:57 AM
    Waverly
    Waverly [OP] Well-Known Member
    West Virginia
    TRD Off Road
    Hood protector Running boards Tonnuea cover
    Is the stuff easy to find...auto part stores???
    I see you can order it on line.
    woody6047...thank you for your service to our Country!!
  9. Nov 11, 2010 at 7:39 AM
    yotaman3130
    Ms
    08 TRD Offroad
    I'd go with AutoGeek.net for te best and good pricing. But they have it at Wally world and autozone. But just like everything else ya get what you pay for
  10. Nov 11, 2010 at 7:49 AM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    I know a guy in a local Subaru club who details professionally.
    After hiring him to do our car one time - that was all it took.
    I do a clay bar treatment to my truck & the wife's car every year now.
    Ideally, I like to do each vehicle every spring to get rid of the winter road grime and once in the fall as a preventative to winter road grime build up.
    The reality of my schedule dictates that I only get it done in the spring :(
    I use the Mother's kit, and I get it at Advanced Auto Parts.
    WELL WORTH THE TIME & EFFORT - DO IT!!
  11. Nov 11, 2010 at 8:13 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    it does not in fact remove scratches... it is to remove or dislodge any foreign objects that have adhered to the paints surface like over spray or rail dust. typically in our recon shop that is the only real use for it. if we had a vehicle that had over spray on it we would use the clay bar with some kind of spray lubricant like a spray wax they work the best or window cleaner depending on what is on the vehicles surface. then we would cut or polish the vehicle with a foam pad and either a cutting agent or a polish to remove any scratches that have found their way onto the car or truck. in fact anytime you touch your vehicles surface with anything and i mean anything you are in fact scratching the paint so smearing clay around on the paints surface will actually cause scratches not remove them. if you are going to use a clay bar make sure and change your surface as you go you do not want to rub the caca that you take off of one section say the hood on another panel of the vehicle, also be light you do not need to press hard undue pressure will almost always ensure that you leave behind scratches.
  12. Nov 11, 2010 at 8:29 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Autogeek has a 15% off sale right now if you join their forum. they also have good BOGO deals on there too
  13. Nov 11, 2010 at 8:44 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    There are two schools of thought as to what a clay bar does. One school says it pull the contaminate out of the paint the other school says it sheers the contaminate off at the surface of the paint. Either way you should have a pretty smooth surface after using the clay bar.
  14. Nov 15, 2010 at 6:29 PM
    08chocotaco
    08chocotaco Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    Trust me, claying your car is DEFINITELY worth it, no matter what anyone says about not doing it. My father owns a car wash in Carlsbad,CA every brand new Lexus, Porsche, and Ford come in from the dealerships and we clay bar them before they sell them. Im 18 now and have worked there for the past 4 summers, clay cars almost every day im there, not that time consuming if you know what your doing and worth it if you ever detail your truck
    Taylor
  15. Nov 15, 2010 at 8:24 PM
    #35
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    its awesome .. takes a lot of time but i calybared my mustang a few times. comes out greaaaat
  16. Dec 15, 2010 at 3:57 PM
    #36
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had never heard of the clay bar before reading about it here. I used the Mothers kit the other day with great results...is the clay in that kit concidered light, medium or heavy?? The reason I ask is I wanted to pick up some more saw some bars at an automotive detailing store that came in different consistencies (light and heavy.) Which one would you recommend that's close to the Mothers clay?
  17. Dec 15, 2010 at 4:15 PM
    #37
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    The meguiars/mothers clay is definitely on the light-medium side. Heavy is typically used for removing overspray. I've only had to use a heavy cut clay a handful of times. You're fine w/ a light or medium cut.
  18. Dec 16, 2010 at 5:57 AM
    #38
    pinktaco808
    pinktaco808 Hot Steppa
  19. Dec 16, 2010 at 11:20 AM
    #39
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    I had heard about "claying" but honestly I was skeptical. My truck always washed & waxed up nice so I was happy. Then reading all the testimonials on TW I decided to set aside a Saturday before the winter set in and see what this clay bar stuff is all about.
    So that Saturday came and I watched the Meguiars how-to video's on youtube and then went to my local Advance Auto Parts and picked up a Mother's California Gold Clay Bar kit on sale for $12. WOW! The results were fantastic! Though it was time consuming it was easy to use. Claying not only smoothed the finish but took the shine to another level. I'm a believer now and claying will be a part of my detailing routine from now on.
  20. Dec 16, 2010 at 9:19 PM
    #40
    pinktaco808
    how often do you clay bar the car
