Clay Bar?
Discussion in 'Detailing' started by Waverly, Nov 10, 2010.
  1. Mar 20, 2011 at 3:50 PM
    #61
    phoneguy44
    phoneguy44 Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    I detail cars on the side from my job. I'm no EXPERT but experience does hold some value. I'm claying and waxing every week. Here are a few tips I've learned:
    **NOTE** Before these steps, clean car VERY VERY good. If the car aint clean, your wasting your time.
    1. You will need a lubricant when claying, NOT a super lube ! You want the clay to grab the grime, if the lube is to slick you wont. Tip: Wash car and pull in some shade. Wet car down again. 2 drops of dawn dishwashing liquid to an already full (water) sprayer makes a great lube. Mix dawn with water, dont shake to make suds, just mix it up.
    2. Knead the clay often !!
    3. You can clay a car very good in 15-20 min. Do small sections at a time, dont just sling your arm across, you will miss spots this way. Go over that small section atleast twice to insure coverage.
    4. I use this clay because you get alot of it for the price and you can use one piece on 2 cars or more sometimes, unless car is in terrible, terrible shape. Inspect your clay, you'll know if you can use it again. I can detail atleast 8 cars with this kit from Poorboys.
    5. Rub your hand across what you've clayed, check for anything that isnt smooth as glass.
    6. REMEMBER, DONT CLAY IF YOU ARE NOT GOING TO WAX. Claying strips wax off your ride. Protect your ride, its the whole purpose you were claying to begin with.
    7. Wash car again after claying. Some will say wipe as you go, I've found this is too much work when I can hit the car with some suds and a wash mit pretty quick. All I'm doing is washing what was clayed.
  2. Mar 20, 2011 at 6:52 PM
    #62
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    All great points :thumbsup:
    To elaborate on the Dawn Dishwashing Liquid
    Dawn Cuts and Strips ALL Waxes
    Wash all wax off with Dawn (& Water) before using the Clay Bar
    That will contribute to the "clean car VERY VERY good", referred to above.
    I got one bottle of Clay Lube Spray with my 1st Clay Bar.
    Have used Dawn and Water as Spray Lube ever since.
    Works as good as the $10 16oz Spray Lube they'll sell ya.
    Oh, and keep lube under the Clay at all times, in other words, spray as needed.
    Thanks for the experienced pointers, Phoneguy44
    CC
  3. Mar 20, 2011 at 7:00 PM
    #63
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  4. Mar 20, 2011 at 8:41 PM
    #64
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Doesn't dish soap fade your paint or something like that. I don't remember where I read that.
  5. Mar 20, 2011 at 8:53 PM
    #65
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Its not an urgent need so I would just wait until winter has fully past and the weather is good, then do a full detailing (wash, clay, polish if necessary, then a synthetic sealant.) That way you have detoxed your car from the winter elements (salt, sand, dirt) and it will look good, and have a coat of protection through the fall (assuming you give it an occasional wash). Then you can do a full detailing before winter hits, and again you have some protection from the elements before the nasty stuff hits.
  6. Mar 20, 2011 at 8:54 PM
    #66
    Cape Codder
    Jack
    Hadn't heard that
    Haven't had the problem
    My Solara is eleven years old this spring
    Still looks like it just rolled out of the Showroom
    28k miles and garaged though :D
    But the point is:
    Multiple Coats of Wax after Stripping and Clay Barring.
    'spose if you didn't wax it after stripping, it would fade in time.
    EDIT:
    CC
  7. Mar 20, 2011 at 9:37 PM
    #67
    pinktaco808
    pinktaco808 Hot Steppa
    wax,wax,wax
  8. Mar 20, 2011 at 9:41 PM
    #68
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    x3 on both of your guys' points for lube, i use a gallon jug i got for cheap of megs 34 i think. its called final touch. good for clay lube. cheap too.
  9. Mar 23, 2011 at 1:02 AM
    #69
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Just incase any of ya lookin. I'm on autogeek.net alot. Boys on there say Target is having a sale on clay bar kits, some guys are finding them for 4 bucks but most are reporting it for $7 if its actually on sale. Dont know if its just some Targets or all, havent checked my local as I just bought $80 worth 2 weeks ago. A kit usually for sales for $21 plus tax.
