Clay Bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by AdamSD, Feb 10, 2014.
  1. Feb 10, 2014 at 6:33 PM
    AdamSD
    AdamSD [OP] Well-Known Member
    adam
    San Diego
    06 Acces Cab 4wd
    What is the best clay bar/detail kit for my 02 white tacoma?
  2. Feb 10, 2014 at 6:48 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I use the Zaino clay kit. But I think you'll get good results from anything as long as you use the proper technique.
  3. Feb 10, 2014 at 6:50 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  4. Feb 10, 2014 at 7:00 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    I use the Mothers once a year before the rainy season along with a good deep wax and im set for the year
  5. Feb 10, 2014 at 7:07 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I like Adam's.
    Their stuff is made in the USA, comes with expert tech support (via their 800 number & forums), and is backed by a 110% satisfaction guarantee. They run periodic sales and Adam's Forum members are always eligible for 10% off.
  6. Feb 10, 2014 at 8:46 PM
    AdamSD
    adam
    San Diego
    06 Acces Cab 4wd
  7. Feb 10, 2014 at 9:33 PM
    Mym Mars
    Mym Mars Member
    Ruby
    Bigfork, Mt
    98 Taco 2.7 5spd 4x4 reg cab
    Mechanically stock, 21.5" led driving light, 4x 4" by 4" floodlights.
    a recommendation from a past exterior detailer is to get some tar remover or lacquer thinner to take most of the tar off first. just avoid your plastic pieces with the lacquer thinner, its causes most of the unpainted parts to fog up white. also you can use a cutting compound on your headlights, taillights, front markers, front turnsignals to freshen em up using a high speed buffer or high speed drill with a polishing ball. good luck!
  8. Feb 10, 2014 at 9:36 PM
    Mym Mars
    Mym Mars Member
    Ruby
    Bigfork, Mt
    also use a hair water spray bottle filled with water for the clay lube, more is better, and mix the clay onto itself regularly so that it is most effective.
