Clay barring
Discussion in 'Detailing' started by redezman, May 16, 2010.
  1. May 16, 2010 at 2:35 PM
    redezman
    redezman [OP] Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    I know you need to keep spraying it as you use it, someone said 3-4 drops or dish soap to a spray bottle.
    BUT
    can you hurt or do damage to the paint?
    I have never tried to do this BUT want to.
    TIPS or pointers would be great.
    This forum has NOT let me down yet,
    Thanks in advanced to everyone that responds.
    ALSO
    whats best clay to use and do in garage or in sun light..
    Thanks again
  2. May 16, 2010 at 2:55 PM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
  3. May 16, 2010 at 4:05 PM
    redezman
    Charles
    Raleigh N.C
    AWESOME video,
    thanks man bunches.
    i watched the one you posted plus a few more and learned alot.
    thanks again
  4. May 16, 2010 at 6:17 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    You won't hurt the paint by clay barring dry. It simply won't work. Clay doesn't slide dry, so it will stick and stretch and get nasty. That's why you use soap. Partly as a cleaner and partly to make a slippery surface for the clay to slide on. Make sure to fold the clay over A LOT while doing your truck so dirt doesn't build up and scratch. Never clay in sun. It takes all the wax off so it leaves your paint unprotected. Wash before and after claying.
  5. May 17, 2010 at 2:32 AM
    redezman
    Charles
    Raleigh N.C
    thanks guys for the great tips
  6. May 17, 2010 at 7:57 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    About the only "damage" you can do to the paint would be some slight surface marring. Clay is an abrasive, and depending on how hard the paint is or how aggressive the clay is, you can get some marring, which will kinda look like holograms on the surface. Most over the counter clays (ie: meguiars, mothers) are very mild and wont cause this. If it does occur, a mild polish will easily clean it up.
    If you use soap, use it liberally. I'd put more than 3-4 drops in personally. Soap is ok to use, but I find that it does degrade, or break down the clay much quicker than a real clay lube will. Spray a 1x1' section at a time and work that area until you're ready to move on, then repeat. Move the clay in back/forth or side/side motions using light to moderate pressure. You can use a little more pressure on stubborn contaminents.
    Definitely try to work in the shade. Reason being, the sun will dry out the clay lube on the surface of the vehicle too quickly for you.
    And for a good over the counter clay, try to find clay magic (blue bar).
  7. May 17, 2010 at 2:48 PM
    redezman
    Charles
    Raleigh N.C
    thanks so much.
  8. May 18, 2010 at 11:29 AM
    BLUETACOMA10
    BLUETACOMA10 Well-Known Member
    Kansas
    2012 TRD Off Road
    Window tint
    Just did my brand newTaco yesterday, and what a difference :eek:. it worked really well and it actually looked liked a darker shade of blue after the waxing..
  9. May 20, 2010 at 5:39 PM
    Turdburglar
    Turdburglar Well-Known Member
    Enola, PA
    '10 DCSB SR5
    Trifecta, AVS Bugflector, TRD skid plate, 45% tint front windows, Gerber carseat lol
    Tried a new (well, new to me) way to clay/wax last week. Instead of washing and drying then claying, I changed it up. I washed one section, then claybarred it while the soap was still on. I had to use some of the detailing spray but the soap/spray combo worked great and saved me a good 1/2 hour over my old way. The only thing you have to do after claying is a quick soapy wash over everything because the detailing spray will streak while drying. When you dry it all off you're ready to wax.
  10. May 20, 2010 at 11:18 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    I wouldn't clay it with a mix of car soap. That will dry out your clay and make it not easy to work with. Sometimes, make it useless. I recommend washing the soap off, then spray your soapy water on the wet vehicle.
  11. May 21, 2010 at 11:38 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    You can also use quick detailer. Your best bet is to buy Clay Magic at Autozone or Kragen for about $12. Then buy an additional bottle of quick detailer in case you run out of the Clay Magic stuff. Clay, polish and wax.
