Clean and Adjusting TPS?
Discussion in 'Performance and Tuning' started by ETaco23, Mar 14, 2009.
  1. Mar 14, 2009 at 8:22 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I haven't found a thread or right up on how you clean and adjust the TPS. I would love to know how this is done.:D
  2. Mar 14, 2009 at 8:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I was always told its bad to try and clean it. I think Tacomaman (Will) cleaned his without issue, thouhg. Check with him.
  3. Mar 14, 2009 at 8:29 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    I cleaned mine. Electronic cleaner stuff I got at Napa worked well.
  4. Mar 14, 2009 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I heard this too, but have no first hand exp. Glad to hear you can clean it.
  5. Mar 14, 2009 at 8:49 PM
    ETaco23
    Evan
    PNW
    thats great to know. Will TB cleaner or MAF cleaner work?
    What about adjusting it? making sure you put it back right?
  6. Mar 14, 2009 at 9:03 PM
    ETaco23
    Evan
    PNW
    Nobody knows?................
  7. Mar 14, 2009 at 9:07 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I dont think its adjustable
  8. Mar 14, 2009 at 9:18 PM
    ETaco23
    Evan
    PNW
    really, I thought I heard that they were.
    Maybe on certain models?
    I just dont want to pull it out, clean it and then put it back in wrong. But if it isnt adjustable then I wont have to worry about that, which would be great!
  9. Oct 7, 2010 at 7:42 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    i took mine apart and cleaned the board with a rag its got little tiny fingers on it but on the 02's you have to brake the plastic case that holds it together to open it... havent drivin the truck yet to see if it was fixed my ecu2 shows it not jumping around too much like it was at idle so i dont know yet ill let you guys know when i know
  10. Oct 7, 2010 at 7:45 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    No adjustment on a TPS, computer controlled.
  11. May 22, 2011 at 12:05 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    OK! bring this baby back from the dead!!!!!
    My 2.7 has a rough idle at 700 RPM's. I sit in traffic and at times it smooths out but the tach never moves. Most of the time when I press the gas to leave the light it seems to die momentarily.
    I have new plugs, filters, cleaned the T/B and inlet but still continues. So this is my next step, TPS!
    Has replacing or cleaning fixed this with anyone?
