Clean, rust-free one owner 1987 4Runner 5spd 22RE w/175K miles
Discussion in 'Buy / Sell / Trade' started by DesertRatliff, Jun 3, 2013.
  1. Jun 3, 2013 at 12:59 PM
    DesertRatliff
    DesertRatliff [OP] Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    *******************SOLD SOLD SOLD. Thanks for the comments and interest!********************
    After 5 years of indecision, my dad's 4Runner has got to find a new, good home. I've never had a harder time selling anything in my life, but life goes on and I need the funds for the next chapter. Not too many one owner 1st Gen's out there in this condition, so I wanted you and the TTORA animals to have the first crack at it.
    Truck lived in Flagstaff, AZ for 24 years but spent the last year and a half with me in Durango, CO. PM me with questions. Serious inquiries only please.
    1987 Toyota 4Runner DLX 4WD
    -22RE with 5 speed. 175, xxx original miles on motor and chassis.
    -PS/PB/AC/MT/EFI, Tilt wheel, manual windows and door locks
    -One owner, all original, 99 % stock, rust-free Arizona truck.
    -Dealer serviced most of its life.
    -Recent tune-up (spark plugs, wires, cap, rotor, O2 Sensor) and oil andfilter change, K&N filter serviced, gearboxes topped off, clutch system and brake system flushed and refilled. Ready to go damn near anywhere.
    -Timing chain, original clutch and throw-out bearing were replaced bydealer at around 100K.
    -Ever Start battery purchased 10/5/10.
    -30x9.50 R15 BF Goodrich A/T’s w/ less than 10K on them. Rolling onEagle Alloy 6 hole rims.
    -Brand new Sony AM/FM/CD/USB/AUX-input deck with 4” Boston Acoustics speakers, Dual Audio 400watt amp and 10”MTX Blue Thunder subwoofer with custom interior-colored cover.
    -Forward E-Brake cable replaced 4/18/12.
    -period correct Actron LED tach.
    -Class III tow hitch with 4 pin connector (only used twice to tow a jetski to a lake).
    -Rancho Add-a-Leaf helps the saggy original leaf springs.
    -Thule ski and bike rack.
    -If it’s not listed above, it’s all original.
    The Good (full disclosure):
    -My dad was the original owner and the sale includes the originalwindow sticker.
    -90% of all receipts.
    -Oil changed at or before 3K its entire life and all service was doneto the book.
    -Fiberglass shell was never removed and original seal is unbroken and leak-free.
    -Runs strong and very reliably. Burns no noticeable oil between 3K oil changes (although sometimes puffs a quick puff of blue on very cold mornings at start-up). Gets 20-22 mpg(have seen 27 once or twice). Never, not once, has it ever let us down.
    -4WD works and works well. 4WD-Hi engages at any speed below 60mph. Lowworks as it should, too.
    -Original Aisin hubs engage smoothly.
    -5-Speed is silky smooth in all gears.
    -Body and chassis are nearly rust-free.
    -Interior is clean and in good shape for an original,used-as-it-was-intended 25 year old truck. Was garaged most of its life. Non-smoker,no other tears or rips (see below)
    -Heat, A/C (with belt attached-see below), speedo, odometer, temp,tach, rear wiper and defroster and all indicator and interior lights work well as do door locks,latches, windows (smooth up and down), 12V outlet, factory clock, E-Brake, Fuel door pull and lock, seat belts, etc. etc.
    -Clean, clear AZ title
    -Comes with window sticker, Toyota Owner’s manual, Toyota Owner’s Guide,tire change tools w/bottle jack, tool roll and a well-worn Hayne’s manual.
    The Bad (full disclosure ):
    -Could use new shocks. Rancho RS5000’s are 15 years old now and one is leaking
    -Original driver side CV boot is torn.
    -I didn’t fix either of the above because it was my intention to cut the IFS off and replace it with a lifted solid axle.
    -Original paint is starting to fade and clear coat is pealing in spots. Looks good from 15 feet though!
    -Small dents as indicated in pics from a full, long life.
    -A/C compressor belt was removed for maximum HP. A/C blew cold when the belt was removed 2 years ago, but compressor bearings do make some noise.
    -Tear in original driver’s seat from getting in and out of truck overthe years. Stitched closed, taped and covered with seat covers.
    -Crack in dash where most of these old dashes cracked. Recently covered with a new DashMat.
    -Some of the plastics are getting pretty brittle and are beginning to crack or have cracked and were fixed. Pics are representative of the condition.
    -Rear window goes down with key from back of truck, but does not go up from outside and requires getting in and rolling up from working full-function interior center console switch. Another common problem that I’ve noticed.
    -Fuel gauge reads a full tank, but drops off to nothing after ½ tank. Low fuel light works and leaves about 40 miles of driving. It sounds like the sending unit is wonky. Requires pulling the tank and since the low fuel light works, I've never bothered fixing it.
    The Bottom Line:
    This would make a good reliable daily-driver or awesome project rig asmost of the stuff that needs replacement would be removed anyway. I would be willing to replace the shocks andthe torn CV if the price is right, but I haven’t bothered because I was always hoping to cut off the IFS and replace it with a lifted solid axle. I’m hoping this truck goes to an owner who will carry out this dream. My dad was the original owner and loved this truck. He never got rid of it because henever needed to; this truck does it all. It’s a clean, reliable, classic Toyota ready for a new home.
    Asking $4300 . Priority will go to a future owner who will go SAS and I will do everything I can to help with transport or delivery . Lowballers, tire kickers or D-bags will promptly be ignored.
  2. Jun 3, 2013 at 1:01 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
  3. Jun 3, 2013 at 1:05 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Carpets were shampooed after these pics were taken. Can shoot new pics if desired, but carpets look even nicer.
  4. Jun 3, 2013 at 1:05 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Dang! Good price too. GLWS.
  5. Jun 3, 2013 at 1:06 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    GLWS...looks like a super clean Runner. Just curious, why would priority go to someone who would SAS it as opposed to preserving an excellent vehicle?
  6. Jun 3, 2013 at 1:07 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
  7. Jun 3, 2013 at 1:07 PM
    4Bangin
    4Bangin Member
    Alex
    Michigan
    2010 4-cyl 4x4 SR5 5-spd
    Beauty
  8. Jun 3, 2013 at 1:09 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
  9. Jun 3, 2013 at 1:12 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    maybe it was a plan of the OP to SAS the vehicle but just didnt have the funds and he would like to see his dream still happen on the vehicle
  10. Jun 3, 2013 at 1:19 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    ^^^You got it. We both always wanted to go SAS with a very mild lift and 33x10.50s...but...well...hoping the future owner will and I can follow along from afar.
    There are a few trashed, rusted out 1st gens here in town and I figure if someone puts $3K into a conversion, they're more likely to take care of it and have fun in it rather than just run it into the ground.
  11. Jun 3, 2013 at 1:23 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I refuse to sell my Pickup to most people for two reasons. 1.) they just don't offer enough for me to feel right letting go. 2.) it always sounds like they want to chop it up and smash it.
    That's what the old rusty ones are for. If there are ones like my mediocre or your mint one, they need to be kept alive. These things are going to be extinct in a quater century if everyone keeps annihilating them ha
  12. Jun 3, 2013 at 1:29 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Great little 4runner there! GLWS
  13. Jun 3, 2013 at 2:47 PM
    daleyswanson
    daleyswanson Active Member
    Enterprise, AL
    6spd 05 DCSB 4X4
    Got rid of the Dungflops. Lift to come.
    Good god that is gorgeous. If I was in the market you would already have my monies.
  14. Jun 3, 2013 at 6:03 PM
    mike89
    mike89 Well-Known Member
    Mikey
    San Diego
    07 TRD Sport 4x4
    Radio Kenwood DNX890HD Two 10in JL 10w1s Upper control arms Donahoe Racing 2.5 adjustable front coil over's Donahoe Racing rear remote reservoir Deaver Add a leaf 33" Nitto Terra Grappler tires Custom 17" seven spoke black wheels cold air intake Throttle body spacer 3" cat back exhaust Race Radio Garmin GPS TRD seat covers TRD floor mats Drilled and slotted front brake rotors Billet front grill Custom built front off road bumper Three off-road lights Hid headlights LEDS Map Lic plate running lights dome
    $4300. thats really low!!! Great runner. bump!
  15. Jun 3, 2013 at 6:08 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Dammmm that's mint . Glws
  16. Jun 5, 2013 at 11:46 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Sale pending.
  17. Jun 5, 2013 at 12:14 PM
    buggsislandtaco
    buggsislandtaco Well-Known Member
    K.B.
    Southside Va
    '01 SR5 TRD Lunar Mist
    Deck Plate Mod, Aftermarket Chrome Bumpers, Ride Rite Airbags, Optronics Running Lights X Tang Tuff Tonneau
    I hope the new owner does it justice. Very nice 4 Runner.
  18. Jun 5, 2013 at 12:18 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    My goodness, that thing is b-e-a-utiful! I wish I had some extra cash...
    Hopefully the new owner keeps it in as good of shape.
  19. Jun 5, 2013 at 12:27 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for all the love, guys.
    Hardest thing I've ever had to sell. The new owner's name is Mike. My dad's name was Mike. Just feels right...
  20. Jun 6, 2013 at 9:35 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    awesome! hopefully he takes care of that beauty!
