Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Feb 19, 2017 at 6:32 PM
    #181
    GPLarge
    GPLarge N1ALW
    Al
    Central CT
    2016 Tacoma SR5 Access Cab 4X4 2.7L
    you probably could. They use the same mic. Just use a 6 conductor wire to run between the radio and a 6 pin keystone jack.
  2. Feb 19, 2017 at 9:52 PM
    #182
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Getting the Galaxy DX-98VHP tuned. 200watt. Getting it from Bells CB in Florida. Wilson 1000 antenna. Road Devil Amplified Mic. Can't wait. Go big!!
    OZxpeditions and Durango95 like this.
  3. Feb 19, 2017 at 10:17 PM
    #183
    Cows Have Claws
    Cows Have Claws Well-Known Member
    Oregon
    2024 Tacoma Trailhunter 6ft
    This is fantastic, you dont happen to have more pictures of this mod do you? I love it! It looks really clean.
    DrFunker likes this.
  4. Feb 19, 2017 at 10:33 PM
    #184
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I can take some. I'll post back in a day or two and quote you so you see it.
  5. Feb 20, 2017 at 4:29 PM
    #185
    Duckman
    Duckman n00b Extordinaire
    Somewhere on the River
    17 White TRD ORDC TECH 4X4
    Guwd gawd.... Please noo.
    Durango95 and Crom like this.
  6. Feb 20, 2017 at 5:10 PM
    #186
    Braves95
    David
    Central PA
    It won't be turned up all the way. If I'm way in some where I want to b able to get out. There's a switch to turn the amp off and 1 of the knobs to turn amp down. I just want to make sure I'm gonna be good. But does do Ham/ AM/ USB/ LSB 10 meters. And will work on the CB freqs
  7. Feb 20, 2017 at 5:49 PM
    #187
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Here you go.
    If you notice, there is a slight gap between the body of the speaker and the console. The speaker cover has 'nubs' on it that are designed to engage the back of the speaker, and the screws that hold the two parts together pass through them. I was going to grind them off with the Dremel, but got lazy. The photos exaggerate the gap, it's quite unobtrusive in actuality.
  8. Feb 20, 2017 at 6:01 PM
    #188
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    You're from Eureka??
  9. Feb 20, 2017 at 6:04 PM
    #189
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I live in Ferndale, just south of Eureka. We moved out here from Ohio about a year ago.
    You have some personal link to Eureka (CA)?
  10. Feb 20, 2017 at 6:06 PM
    #190
    seniorredwood
    Pennsylvania
    Yea I grew up in Eureka. Been to Ferndale many times. Military moved me to the east coast.
  11. Feb 20, 2017 at 6:07 PM
    #191
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Heh. How about that. I see you are LE also. I worked 20 years as a cop in Ohio and I work for EPD now.
  12. Feb 20, 2017 at 6:10 PM
    #192
    seniorredwood
    Pennsylvania
    Very nice! I used to work at Broese's uniforms before I joined the military. You've probably been there.
  13. Feb 20, 2017 at 6:10 PM
    #193
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    LOL, I have indeed. They are now the only game in town for uniforms.
  14. Feb 20, 2017 at 6:13 PM
    #194
    seniorredwood
    Pennsylvania
    Haha small world!
  15. Feb 20, 2017 at 6:51 PM
    #195
    GORUCKtaco506
    GORUCKtaco506 Well-Known Member
    Glenn
    Orange County, Ca
    2016 TRD Sport 4x4 DCLB Super White
    ARE cx shell with windoors, carpeted sleeping platform, red LED map lights, LED vanity lights, tailgate vinyl inserts, glove box vinyl inserts, dog ramp, blacked front grill and white emblem, blacked badges, debadged tailgate.
    Trying to figure out how to instal my cobra 75. Ive got a few questions. I've got the same bracket, how did you run the coax into the cab? What kind of cable did you use?
    Did you bring a hot wire straight in from the battery or did you go through the fuse box?
    Thanks in advance
    disconnected likes this.
  16. Feb 21, 2017 at 11:14 AM
    #196
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    There are some plugs throughout the cab... I chose one near/under the passenger seat.
    The cable is the Fire-Flex coax from Firestik. 18 feet is just long enough for the DCLB.
    The CB radio I currently use (Midland 75-822) plugs into the cig lighter... no hard-wired hot wire necessary.
    Hope that helps!
  17. Feb 21, 2017 at 6:36 PM
    #197
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    If you were asking anyone... I'll chime in: my two radios (CB and Ham) are wired to battery, but I have other stuff going to the fusebox.
    For ease of use, the fusebox is nice; and easy to tap with a mini-ATO tap. The 'AW1' 5A fuse is always hot if you want constant power for a low amp device like a CB or a cell phone charger. Most other fuses are ignition switched if you want power to turn on and off with the ignition.
    The bolt holding the fusebox to the dash subframe is grounded, so it's easy to run your wiring to the fusebox and terminate both + and - right there next to each other, keeps everything tidy.
    disconnected and I'mTheDude like this.
  18. Feb 21, 2017 at 7:01 PM
    #198
    GORUCKtaco506
    Glenn
    Orange County, Ca
    All help is appreciated, thanks for the info.
    It does, thanks for the input
  19. Feb 22, 2017 at 4:39 PM
    #199
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    Much slippage.....
    You, fine sir, RAWK!
  20. Feb 25, 2017 at 9:37 AM
    #200
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Where did you find the blank switches? I want modify one to use as a keystone mount for my mic.
