Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Feb 2, 2022 at 2:18 PM
    #2061
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Yes. You use a momentary on dash switch to manually flip/flop. With more ingenuity you can force a flop (off) at power down.
    Remember a simple 40 amp auto relay coil activated on ignition will do all this for pennies. It is only if you are worried about rfi AND you might want power on with ignition off sometimes that you might want to explore a latching relay.
    jsackspot[QUOTED] likes this.
  2. Feb 2, 2022 at 3:18 PM
    #2062
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Many modern ham rigs have an auto power off feature.
    vicali, Cudgel and jsackspot like this.
  3. Feb 2, 2022 at 3:56 PM
    #2063
    jsackspot
    jsackspot Well-Known Member
    Right, except the Rigrunner (which is weird that I haven't seen much by way of power distribution setups) I have in between the battery and radio does not.
  4. Feb 2, 2022 at 3:59 PM
    #2064
    jsackspot
    It makes so much sense now that you mention it— having more control is fantastic. I'm just thinking through the user experience here and if it seems right— the switch should light up if it's on, indicating it's on, and so it should not come on (or display a darker lamp) if the ignition is off. That's something to consider. Example: it's on, you shut the engine down, but the switch remains lit, while the rest of the cab stays off.
  5. Feb 2, 2022 at 4:25 PM
    #2065
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Tada! Have the work is making it cool!
  6. Feb 6, 2022 at 1:20 PM
    #2066
    TacoNoVeggies
    TacoNoVeggies Well-Known Member
    San Diego, CA
    '20 Off Road ACLB Quicksand
    Stock
    Trying to find the tool name to cleanly cut a hole in the roof. Hole saws weren't the answer, were they?
    k8md likes this.
  7. Feb 6, 2022 at 1:26 PM
    #2067
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    Larsen NMO holesaw.
  8. Feb 6, 2022 at 2:07 PM
    #2068
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    "Antenna Hole Saw." You can find them on Amazon and other places. The problem with a regular hole saw is that there is no stop so it's very, very easy to go right through the headliner.
    Gunshot-6A and GarlicFarts like this.
  9. Feb 6, 2022 at 2:51 PM
    #2069
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    step bit? Looks like a cone with different diameters stacked up?
  10. Feb 6, 2022 at 4:28 PM
    #2070
    HisDad
    Texas at last
    NOOOOOOOOOOOOOOO!:annoyed:
    Seriously, that's an almost perfect way to destroy something. If your drilling through the roof, you can go through the headliner or worse. It's ridiculously easy to drill too large a hole and then you're really screwed.
    I've owned one of the original Cone Cut bits since the 1970s and still don't trust it.
    rainsux, k8md and panicmonster like this.
  11. Feb 6, 2022 at 4:32 PM
    #2071
    golfindia
    Yes.
    pickup truck
    No.
    Greenlee punch.
  12. Feb 6, 2022 at 4:58 PM
    #2072
    HisDad
    Texas at last
    I've used them, but they are less than ideal. You have to be able to get to both sides of whatever you're drilling. Again, using a roof top installation, that means taking the headliner down. Which might not be a problem with a Tacoma, I've never installed an antenna on the roof of one. I've used a Greenlee on trunks of sedans and they work well. For any other surface, you have to look carefully at the work before you start.
    Which is good advice for anything involving drilling, cutting, or even using sheet metal screws. Measure a dozen time if necessary and then cut, drill, saw, or screw.
    Gunshot-6A and TacoNoVeggies like this.
  13. Feb 6, 2022 at 5:19 PM
    #2073
    atpage
    atpage Well-Known Member
    Western NY
    Worked fine for me. :shrug:
    Of course, I made sure the headliner was out of the way, and triple-checked what size I needed first.
    pmoore4321 likes this.
  14. Feb 6, 2022 at 6:36 PM
    #2074
    GarlicFarts
    Lil Rhody
    Drop the headliner first? :notsure:
    I was just seeing if that's what he was Thinking about since a hole saw wasn't it. I don't have plans to cut holes in my roof so I haven't looked into what the best options are.
  15. Feb 7, 2022 at 11:45 AM
    #2075
    RScottie
    RScottie Well-Known Member
    Eastern Kentucky
    2022 Blue Crush Tacoma SR5 4x4
    Has anyone drilled the 3/8 hole out on the Victory 4x4 mounting bracket to handle a CB Antenna stud?
  16. Feb 7, 2022 at 12:08 PM
    #2076
    HisDad
    Texas at last
    If you're doing a one time installation, you can do that. If you're a commercial operation, you probably want to be more efficient. The other complication with a roof mount is air bags. A and B pillars often have airbags. C pillars are less likely.
  17. Feb 7, 2022 at 1:19 PM
    #2077
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I use mine all the time, much cleaner and way more accurate than a hole saw though they have their uses, just Sharpie the proper diameter of the step drill. It’s not like they go so fast you can’t control when it stops and they come in a variety of sizes and increments. As with any drill they produce a lip on the inside and you’ll want to cold galvanize the bare metal before sealing. Anytime you drill anywhere on your truck you want to be damn certain what is or isn’t behind it. Drill stops do ok but if it were production work I’d want the stop permanently fixed for the correct depth. It’s ridiculously easy to fuck up anything but it’s not that hard not to.
    GarlicFarts likes this.
  18. Feb 7, 2022 at 7:54 PM
    #2078
    TacoNoVeggies
    San Diego, CA
    Stock
    Thanks to everyone for their help!
    I think the greenlee was the one people were talking about earlier in this post. I remember now the issue was how expensive this was.
    Do anyone know of places that rent these or if the Harbor freight versions are any good?
  19. Feb 8, 2022 at 4:30 AM
    #2079
    golfindia
    Yes.
    pickup truck
    I've never used them, but the HF punches are probably sufficient to do a hole in a car body panel. Lube the threads well.
    But... unless you're good at fixing F-ups (like me), it's probably worth the money to just buy a real greenlee to start with.
    TacoNoVeggies likes this.
  20. Feb 8, 2022 at 7:16 AM
    #2080
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Look up you local radio shop, they do commercial installs all day long. Talk nice and I bet they’ll put a hole in your roof for you for $20.
    TacoNoVeggies and GarlicFarts like this.
