Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Dec 8, 2022 at 6:30 PM
    #2301
    gvfs
    gvfs Well-Known Member
    43° North
    2023 Black TRD Sport AC 6MT 4x4
    I should have clarified. I have a stack of 2m/440s on my desk, including the Kenwood and the Yaesu. So that money already has been spent. HF is more of an afterthought. I have an FT-817 (QRP) or an 857D I could use for that.
    Good to hear. I have been leaning that way. The plan is to chase the necessary wiring once rather than every time I add a contraption, and that's what the Switch-Pros devices and their competitors--whether solid state or relay-based--offer.
    I'm going to be checking forward and reflected power to get the SWR as close to 1:1 as possible.
    It would aesthetically be jammed into a safe spot up under the bed if I can find one, but, yes, I will be avoiding leaky ammo boxes and the like. The Byonics APRS unit is around 5"x1.5"x0.75", so a very small enclosure would do, with just enough room to wrap the unit in foam.
    I'll check that out. It would need to work with snow/ice and window scraping.
  2. Dec 8, 2022 at 6:40 PM
    #2302
    gvfs
    43° North
    The MTT4BT-40 is a 40W digipeater, so it services a significant area around the vehicle. I messaged that guy in Hawaii about an "APRS" label for the Switch-Pros panel.
    BEAR_KNIFE_FIGHT likes this.
  3. Dec 8, 2022 at 6:50 PM
    #2303
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Not to put too fine a point on it, the fuel pump RFI is brutal.
    N4GI
    gvfs[QUOTED] likes this.
  4. Dec 9, 2022 at 5:32 AM
    #2304
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    You should really read this article, especially about the BMS on modern vehicles. I used to hook directly to the negative of the battery on older cars, but with the BMS on newer cars I go to the chassis ground point.
    http://www.k0bg.com/wiring.html
    Just something to consider.
    Comm_Guy likes this.
  5. Dec 9, 2022 at 6:31 AM
    #2305
    gvfs
    43° North
    Thanks. That was one of the first things I read. ARRL recommends using the chassis ground point, as it is used by the BMS, and avoiding any VQM in the path on the positive side.
  6. Dec 9, 2022 at 10:46 AM
    #2306
    Comm_Guy
    Comm_Guy Well-Known Member
    Brian
    Vero Beach, FL, USA
    ‘22 Tacoma TRD Sport DCSB
    All about making it more useful, Bed Lights, Power Tailgate Lock, Flat Aluminum Tailgate Cover, Leer Topper with added lighting, Ham Radio, 12V Outlets in bed, 400W Anytime Outlet, Meso Customs Stealth Shifter Knob & Dual Color Cab lights, and bed mounting and organizations.
    Sadly it seems the ARRL doesn't do much actual new research or updating of many of their guides as technology changes, not the first guide I’ve seen that doesn’t follow modern practices.
    HisDad and gvfs[QUOTED] like this.
  7. Dec 9, 2022 at 3:08 PM
    #2307
    Athena32
    Athena32 Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    Thanks for the article! Alan makes some very good points here and as such I'm now considering adding a fuse to the negative lead of my installation. I had to think about it because the information about grounding can be ambiguous if taken at first pass--at least for me. He states that the chassis should never be used for grounding due to galvanic corrosion but then goes on to state that for vehicles using a Battery Management System (BMS), the chassis ground for which the BMS is attached to should be used for grounding the transceiver. At first, the seems to be a logical contradiction. But, given the fact that energy always wants to take the path of least resistance, I suppose that the energy will travel from the transceiver to the BMS chassis ground, through the BMS, and to the battery. As such, if galvanic corrosion were to occur, it would only occur in this small area thus being relatively easy to repair.
    I need to read through the service manual I have and inspect the cables to see if my truck has a BMS and where it might be located. From there, I'll give consideration to moving the negative lead.
  8. Dec 10, 2022 at 1:00 PM
    #2308
    Comm_Guy
    Brian
    Vero Beach, FL, USA
    Decided I need an external speaker for my 2way radio, the audio coming from under my passenger seat isn’t working.
    Where is a good place for a hidden speaker that won’t show but has clear audio to drivers seat and how to mount it, don’t want to drill in firewall or anywhere that will show. Pictures appreciated.
  9. Dec 10, 2022 at 1:18 PM
    #2309
    gvfs
    43° North
    Does "won't show" include having it on the ceiling?
  10. Dec 10, 2022 at 2:30 PM
    #2310
    Comm_Guy
    Brian
    Vero Beach, FL, USA
    Not 100% against it, but I’d like to avoid drilling holes where they would be seen when the speaker is removed for selling the truck so mounting method would be a big factor.
  11. Dec 11, 2022 at 7:41 AM
    #2311
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Nice excuse to get a Meso overhead hex rack. Well, if they’re ever in stock again.
    :thumbsup:
    2Nice likes this.
  12. Dec 11, 2022 at 1:10 PM
    #2312
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what about stashing one behind the lower dash, on the right side of the steering column, where the little vent is for the hvac thermistor?
  13. Dec 11, 2022 at 2:14 PM
    #2313
    Comm_Guy
    Brian
    Vero Beach, FL, USA
    That’s an idea, didn’t realize there was free space back there.
  14. Dec 11, 2022 at 2:31 PM
    #2314
    soundman98
    NW Indiana
    it's an idea at least. i don't know how much free space there is...
  15. Dec 11, 2022 at 5:38 PM
    #2315
    OlympicTaco
    OlympicTaco Wrench Therapy
    ‘20 Pro
    There is also some room behind the head-unit depending on the speaker you get. I put an Icom SP-35 speaker back there and it's plenty loud to hear clearly. The nice thing about this location is that is sounds like its coming from right in front of you. Better than hearing it voices come from under your (or the passenger's) butt. The connecter on that speaker is just a standard 3.5mm jack so if your radio has that output then it will work fine.
    https://www.gigaparts.com/icom-sp-35.html
  16. Dec 11, 2022 at 5:54 PM
    #2316
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    The SP-35 is a great speaker. I have one for my Uniden SDS200 and the audio is good. I have it mounted at the top of the B pillar, which wouldn't work for Comm_Guy since he wants to avoid visible holes. The little cubby left of the steering wheel would probably work, though.
  17. Dec 11, 2022 at 7:08 PM
    #2317
    Comm_Guy
    Brian
    Vero Beach, FL, USA
    Sadly it’s a ‘22 which means no cubby there.
    I have a good collection of speakers already, including a bunch of the little Radio Shack ones I snapped up when they went out of business, those things will fit almost anywhere. Gonna look at the area behind the stereo, I noticed it looked empty when I was hunting for a spot this afternoon.
    I probably worry too much about holes and resell value but I tend to flip cars quicker then I probably should so I like to be able to bring them back to like new condition to get top dollar.
    soundman98 likes this.
  18. Dec 11, 2022 at 7:24 PM
    #2318
    soundman98
    NW Indiana
    top of the b-pillar is slightly concerning for the side impact air bags that deploy from the headliner
  19. Dec 12, 2022 at 5:11 AM
    #2319
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Do you have a pic of this? Do you mean actually behind the head unit so you don't even see the speaker? Thanks!
  20. Dec 12, 2022 at 5:36 AM
    #2320
    golfindia
    Yes.
    pickup truck
    I plugged my icom 7000 into the AUX jack....
