Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Aug 5, 2018 at 4:07 PM
    #741
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    I really like the TS-480HX, and I was going to buy one for my Tacoma. I couldn't justify the expense, when I already own an IC-7000. I was considering a Tech Deck to mount the TS-480HX head.
  2. Aug 20, 2018 at 1:00 PM
    #742
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    Regarding installing a NMO mount antenna. Is the best spot to drill above the dome light?
  3. Aug 20, 2018 at 6:21 PM
    #743
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
  4. Aug 20, 2018 at 6:46 PM
    #744
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    More or less, yeah.
  5. Aug 21, 2018 at 7:16 PM
    #745
    k8md
    Bob
    I drilled mine further aft, as I might drill a second hole forward of the dome light and I wanted good spacing. I also think it looks better a little bit aft. The headliner is not difficult to drop.
  6. Aug 21, 2018 at 8:26 PM
    #746
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I realize this is an old response but to put it on the record for anyone who finds it, there's an 18mm hole about 8-10" from the bottom of the truck dead center in the back of the cab (edit: in a double cab.. no idea on the access) similar to the plug under the hood people use to run amp cable. I pulled the plug from the outside and there was insulation so I'm guessing it's hidden from the inside but you could drill out the plug and run the cable in through there without adding to the holes in the truck.
  7. Aug 22, 2018 at 3:36 AM
    #747
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Nice find!!! I ended up running my coax along the right side of the frame and up through the grommet where the A/C condensation exits.
  8. Aug 31, 2018 at 8:43 PM
    #748
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    hey guys new to the cb world but deff need one running some of the trails out here in Las Vegas. What you guys think i should get.
  9. Aug 31, 2018 at 10:10 PM
    #749
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    You may want to check out a ham radio. They are much more capable and you can communicate over longer distances. They are becoming more common than CBs.
    moser633[QUOTED], Shellshock and k8md like this.
  10. Sep 1, 2018 at 8:12 AM
    #750
    Two Hawks
    Two Hawks Well-Known Member
    Morgan Hill, Ca.
    2016 Tacoma TRD OR 4X4 A-Cab
    Ham radio antenna,Firestone Ride-Rite air spring Snug Top topper, and a rifle rack y'all ..Moroso Catch Can, De-badged.
    Back in the day I had a Uniden 510 to talk short range to my group..
    Today it's ham radio as CB turned into chaos, don't know what its like today as I never looked back once I went to ham radio. You'll need to pass a relatively easy test to get your tech license, that license gets you into the world of amateur radio. Legally Use higher power than CB and be able to communicate short or long distance. You can step up to the next level license and talk world wide. Or you can look into GMRS, which also needs an fcc license which doesn't require a test just cash. It all boils down to what your needs are.
    Any radio is better than none specially if there is no phone service. Cost have come down in ham radio as a Chinese made ham radio start at ridiculously low prices. If CB is still your choice look into Uniden 510 (compact unit) or Cobra ssb radio for more flexibility..
    73 to ya..
    moser633[QUOTED] likes this.
  11. Sep 1, 2018 at 8:25 AM
    #751
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    I know a few guys running a Cobra 75WXST and really like them. They are small and have the weather channels on them. I had one and had reliability issues with it. I'm running a Uniden PRO520XL. So far the only complaint I have is no weather channels, but I get them on my ham radio. The biggest limiting factor in the Tacoma is space. Unless your okay with mounting on top of the dash, your going to need a small radio. Just remember there is a knee air bag on both sides.
    As @sdsurfer mentioned guys are starting to switch over to ham. The two biggest downside's are cost and you need a licence, but that's really about it. You're around $100ish for a good CB, a decent ham radio starts around $200 if you just want the 2M band. Add the 70cm band and they start around $300 for a decent one. They have considerably more range then a CB. CB's are limited to 4 watts, the ham radio the I'm running can put out 50 watts. The other big plus is a lot of the the ham radios have a detachable face plate. For me I have the body under the seat and the face plate on the dash.
    Whether you get a CB or ham depends on who your with and what the area your in uses. I have both because I need a CB for my job and a lot of guys around here still use a CB on the trail, but some of the guys I run with use a ham radio and the ham's range would be much better in an emergency if you don't have cell signal.
    NotRed and moser633[QUOTED] like this.
  12. Sep 1, 2018 at 9:34 AM
    #752
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    Where did you get that compressor mount??? I have the dual batteries as well and no where to mount a compressor.............
  13. Sep 2, 2018 at 12:30 AM
    #753
    medic2230
    Murph
    Bama! Roll Tide
  14. Sep 9, 2018 at 6:03 AM
    #754
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Anyone using the hondo garage unholey mount?
  15. Sep 9, 2018 at 6:06 AM
    #755
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    I use one to hold my cell phone. I paired it with a Ram X-Grip.
    Ayeele[QUOTED] likes this.
  16. Sep 9, 2018 at 9:22 AM
    #756
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I had one in my (now sold) Taco. Good piece of kit!
  17. Sep 9, 2018 at 9:46 AM
    #757
    Papadave418
    Papadave418 Well-Known Member
    I plan on doing something similar but using mount which reinforces what you did and gives threads for the ram ball mounts.
  18. Sep 9, 2018 at 8:46 PM
    #758
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    I use the vent ring with a custom printed mount that accepts a small bushing attached to my radio faceplate. Makes it quick and easy to stash the radio.
  19. Sep 9, 2018 at 9:07 PM
    #759
    Ayeele
    Houston, Tx
    Awesome. I just ordered it. Ram ball and cb mic holder thingy
    forty2[QUOTED] likes this.
  20. Sep 10, 2018 at 9:40 AM
    #760
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Got my Ham license on Saturday, now the planning begins...
    Are their any dual band radios with all of the controls and display in the handset, similar to the Cobra 75WXST? Should I just suck it up and get a radio with a detachable faceplate? Now that I've already got a CB mounted in the armrest, I'm going to have to get a little more creative with the ham.
    Two Hawks and k8md like this.
