Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Dec 10, 2018 at 11:51 AM
    #941
    EightGodzillas
    EightGodzillas Scales of Justice
    Lake Norman
    2018 Tacoma TRD OffRoad
    DangerClose, 5nahalf and Sand Dog like this.
  2. Dec 10, 2018 at 12:08 PM
    #942
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    If you don't mind crimping your own keystone jack [easy to do], theres this. I have it for mine, just not installed yet.
    https://www.shapeways.com/product/22APYPH5F/short-toyota-switch-blank-with-keystone
  3. Dec 10, 2018 at 12:15 PM
    #943
    EightGodzillas
    Lake Norman
    Does that hold an RJ45 female connector?
  4. Dec 10, 2018 at 12:17 PM
    #944
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Yes. Keystone jacks are the standard for wall-mounted RJ-45 connectors. That shapeways link doesn't come with the connector, you will have to supply that yourself.
  5. Dec 10, 2018 at 1:12 PM
    #945
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I put my radio power, antenna, and driving light wires through the main grommet beside the hood release. Had it the same on the 2nd gen. You can carefully put a hole through and use a wire/coat-hook trip if you need to, I successfully put a PL259 through there so there is a lot of room.. It comes out just above the brake pedal inside. No dash work necessary. I ran it over and behind the foot panel, down along the door sill under the trim and over under the front seat - you could keep going into the back seat compartment.
    Bastek likes this.
  6. Dec 10, 2018 at 1:28 PM
    #946
    EightGodzillas
    Lake Norman
    So that is where I was trying to poke through. I'm concerned about cutting a wire. What did you cut the grommet with?
  7. Dec 10, 2018 at 3:02 PM
    #947
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    The wiring harness is in the middle through the hole, the grommet is around the outside, so your wires aren't really near or through the same holes as the harness; I took an exacto, clicked out just a 1/4" of blade out and slowly pushed it through beside and away from the main harness. Start with the smaller wires going through and work your way up. You can tape new leads to the wire that's already through and pull it along..
  8. Dec 10, 2018 at 3:06 PM
    #948
    2016 Access in White
    2016 Access in White Well-Known Member
    2016 TRDOR Access
  9. Dec 10, 2018 at 6:31 PM
    #949
    dziner
    dziner Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    I used a Relentless Fabrication hood hinge mount for the FireStik. Then ran a 10 AWG ground wire to where the battery is grounded. This wire connects on the under side of the antenna mount. I'll have to get some photos. I ordered a new FireStik Firefly 3' antenna to replace the one I have. So I'll see what I get with the SWR meter when I attach the new antenna and try to dial in the tip.
  10. Dec 10, 2018 at 6:57 PM
    #950
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Check what you'll get after replacing the antenna. If you will be able to tune it ok then :thumbsup:.
    If you still ran into tuning issues, I'd suggest shorter flat ground strap instead of longer standard wire. *that is supposed to make a big difference in ham antenna installation, not 100% sure about cb... So hopefully you'll be fine with what you got :fingerscrossed:
    dziner[QUOTED] likes this.
  11. Dec 11, 2018 at 9:50 AM
    #951
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    This is a terrible idea. If you do it, you could damage your equipment because the antenna will be so far out of tune.
  12. Dec 13, 2018 at 11:43 AM
    #952
    EightGodzillas
    Lake Norman
    Did we both mean RJ-11?
  13. Dec 13, 2018 at 11:48 AM
    #953
    EightGodzillas
    Lake Norman
    Has anyone made switch holders for this plate? And is there a thread explaining how to wire something from this point, down the A pillar and into the dash? I can't find these.
  14. Dec 13, 2018 at 11:56 AM
    #954
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Looks like yes.
    https://www.hamoperator.com/Fusion/FusionFiles/K9EQ-FUSION-PDF-0005_Extension_Cables.pdf
    Also, in regards to your next post: yes, here. This is just the center part but the seller also makes the left and right side. I ran my cables down to the drivers side A-pillar, just unbolt it all and run it BEHIND the airbags. It's pretty easy. I also dropped out my visor [turn the clip 45 degrees, it should pop out. unscrew (phillips head) the other part] to give a bit more slack in the headliner.
    https://www.shapeways.com/product/8...-overhead-center-switch-panel?li=shareProduct
  15. Dec 13, 2018 at 12:50 PM
    #955
    EightGodzillas
    Lake Norman
    Thank you!
    BEAR_KNIFE_FIGHT likes this.
  16. Dec 14, 2018 at 5:59 AM
    #956
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
  17. Dec 14, 2018 at 7:09 AM
    #957
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    The little grommet up to the left of the main firewall grommet is even easier to run cable through if you just have a few cables. Just cut out the center piece to whatever diameter. And you can always buy a replacement if you want to return to stock.
    vicali[QUOTED] and Mtn Mike like this.
  18. Dec 14, 2018 at 7:53 AM
    #958
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Made an addition
    shiftd, Cudgel, medic2230 and 2 others like this.
  19. Dec 14, 2018 at 7:54 AM
    #959
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Good stuff! Thanks
  20. Dec 14, 2018 at 8:47 AM
    #960
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Anyone ever try making a power folding antenna?
    Was thinking it would be pretty cool to push a button and have my antenna flip up. Then when parked it flips down.
