Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. May 21, 2019 at 10:47 AM
    #1201
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Thanks. I ordered it and got it installed yesterday. Super nice unit. I'm always amazed at the quality HAM stuff you can get for the money. This feels every bit as tough as our work radios and those things are bulletproof - and a few grand a piece.
    Dropped into the 2nd gen like a boss...
  2. May 21, 2019 at 2:49 PM
    #1202
    Tacoman97
    Tacoman97 Well-Known Member
    andrew
    new york
    2018 Calvary blue TRD PRO
    question, i wana hook a cb up in my 3rd gen but i want to leave it on and have it turn on and off with the ignition. anyone have any recommendations on where to tap power from? also is it bad to leave cb's on and just cut the power to them?
  3. May 21, 2019 at 3:14 PM
    #1203
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I had mine linked to the 12v outlet fuse with a "add-a-fuse" link. Then I just left it on and it turned on with the ign. Now I have a switch on the dash though, but I can leave the switch on, its keys to the ign
    Tacoman97[QUOTED] likes this.
  4. May 21, 2019 at 3:19 PM
    #1204
    Tacoman97
    andrew
    new york
    another question, does anyone here have the RAM mounts on the dashtop multi mount? i was thinking of mounting my cb that way but wasnt sure how strong those ram mount balls were. if they would hold the weight of a cb over a while or get loose. anyone know about them?
    KY_Rob likes this.
  5. May 21, 2019 at 3:36 PM
    #1205
    5nahalf
    Erik
    Minnesota
    The ram ball is a hard rubber, the clamps do a very good job of keeping them in place. I would venture to say the ram ball is stronger than whatever part of the dash you mount it to.
    Durango95 likes this.
  6. May 21, 2019 at 5:51 PM
    #1206
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I have the dmm. What CB are you planning on mounting up there? And are you talking about the radio body or a remote faceplate?
  7. May 21, 2019 at 5:54 PM
    #1207
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    The DMM with RAM balls is rock-solid. Check out the quote from that thread below. I think you’re question will be answered there.
    Durango95 and SigBoy[QUOTED] like this.
  8. May 21, 2019 at 6:44 PM
    #1208
    Tacoman97
    andrew
    new york
    wow nice, im looking to run a uniden 980 with a small uniden scanner placed on top. i wouldnt have the ram mount holding the thing way in the air but i just want it so that its not rubbing on the dash so it will be supporting just very little in the air. thanks for the help guys. anyone here have the uniden 980?
    KY_Rob likes this.
  9. May 22, 2019 at 8:12 AM
    #1209
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Go with a larger RAM ball IMO. A 1.5" should work just fine and they aren't coming loose if you snug it down properly.
  10. May 22, 2019 at 8:13 AM
    #1210
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    So I'm about to go punch a hole in my truck... anyone dropped the headliner on a third gen? I've seen the second gen threads and videos but I'm really hoping I don't have to pull all 6 pillar trim pieces...
  11. May 22, 2019 at 11:11 AM
    #1211
    ClutchTaco
    ClutchTaco Well-Known Member
    Mark
    2018 White TRD Pro 6spd
    265 75 16 Duratracs
    Still working on the radio install, but I think this fits here (Laird, NGP GMRS Phantom):
    EwJhYxxZj_5pkAf67aApW7huP_DoGhvParpdFkB3_8231f9ef32c7af1bb02cb9a84cd19012457c1f12.jpg
    shiftd, rkcrawl, rlj251 and 9 others like this.
  12. May 22, 2019 at 12:32 PM
    #1212
    SigBoy
    SigBoy Well-Known Member
    2020 TRD Off-Road, Access Cab
    I have done it, but did not make a video. Probably a good thing too because my first drill location was too close to a support pillar and I had to drill a second hole further back. :( At least they make NMO hole plugs.
    To access under the headliner, I had to remove the front and middle plastic column covers (double cab). This allowed me to pull coax from the top hole down along the middle support column.
  13. May 22, 2019 at 12:34 PM
    #1213
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    My plan was to do it near the dome light but as I assumed, there's the support beam. I'll go a little behind it but I don't want to go too far back - I plan on upgrading the roof top tent at some point and it'll likely be a hardshell that overhangs the cab.
  14. May 22, 2019 at 12:40 PM
    #1214
    SigBoy
    Get to the point where you can pull the headliner down a few inches and look before you drill. This is my best advice.
    velogeek[QUOTED] likes this.
  15. May 22, 2019 at 4:18 PM
    #1215
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    2nd gen, DCLB owner, and hole puncher extrodinaire. I only removed the front four pillars and was able to bend it down enough to make it happen. Slide a piece of plywood in there, so the drill doesn't contact the headliner. Also catches the shavings. I thought for sure I creased the headliner, but it's surprisingly durable. The sunglasses holder needs to come down, it was holding up quite a bit!
    What drill? A proper NMO hole saw makes the most beautiful hole. A step bit works, but you'll need to spend some time with a file.
    Edit: and if you're actually using a punch, make damn sure it's the correct size. There are punches out there that are labeled 3/4" because they're for 3/4" conduit. They make a much larger hole then 3/4"!
    KTM753 and velogeek[QUOTED] like this.
  16. May 22, 2019 at 5:13 PM
    #1216
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Very unlikely.
  17. May 22, 2019 at 5:21 PM
    #1217
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Yeah I’ve got the Greenlee punch and I’ve already taken the calipers to it to verify. I think I’ll give the front 4 a shot and see where it gets me.
    Bastek likes this.
  18. May 23, 2019 at 5:21 AM
    #1218
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    When I drilled I took out the 3 pillars on one side. But I would add that I've got the double cab sunroof, so I was drilling just fore of the sharkfin.
    rkcrawl, Ihnaer and k8md like this.
  19. May 23, 2019 at 6:36 AM
    #1219
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Good looking antenna. What brand/model?
  20. May 23, 2019 at 8:19 AM
    #1220
    foy1der
    W1FOY
    2017 OR DCLB
    Thats my parking garage antenna, the Comet SBB-1 it's nearly indestructible, basically a rubber duck for the truck.
    muffyinva likes this.
