Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Jul 22, 2020 at 9:57 PM
    #1621
    Ihnaer
    Ihnaer Well-Known Member
    Sacramento, Ca
    18 TRD Off-Road
    TRD pro grill TRD rhino liner’d skid plate C4Fab Front Bumper w/ winch and Baja Lights DCDC 2nd battery ARB compressor Switchpros GMRS hidden radio Expedition Essentials dash mount Old Man Emu 2" lift DCDC Trailer charging port LED taillight upgrade Weboost cell amp
    Finished up my HAM and GMRS install today. More pics later on the antennas. The radios are mounted under the passenger seat. The GMRS antenna is in the roof and HAM is on a rago mount on the taillight.
    wradar, 4x4cajun, MGM_Grand and 11 others like this.
  2. Jul 22, 2020 at 10:02 PM
    #1622
    medic2230
    Murph
    Bama! Roll Tide
    Something wrong with your ftm-400 screen or just in the pic?
  3. Jul 26, 2020 at 8:52 PM
    #1623
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Those of you who are routing the coax cable from the cab to the bed mount, where are you running the cable through? Is there already a hole or are you drilling a new one?
  4. Jul 26, 2020 at 9:03 PM
    #1624
    medic2230
    Murph
    Bama! Roll Tide
    Believe most are going through the grommet in the floor.
  5. Jul 26, 2020 at 9:23 PM
    #1625
    toottootbeepbeep
    toottootbeepbeep Well-Known Member
    2019 MGM DCLB TRD SPORT~
    there's a grommet on each side, driver and passenger. i pull the rubber grommet, routed the coax through, and then cut a little slit into the grommet so i can still use it with the wire going through.
  6. Jul 27, 2020 at 7:29 AM
    #1626
    Ihnaer
    Sacramento, Ca
    18 TRD Off-Road
    Just the pic. iPhone did a live image and somehow got a weird frame for the main photo
    medic2230[QUOTED] likes this.
  7. Jul 27, 2020 at 8:04 AM
    #1627
    Tacoman97
    Tacoman97 Well-Known Member
    andrew
    new york
    2018 Calvary blue TRD PRO
    What radio is that?
  8. Jul 27, 2020 at 9:24 AM
    #1628
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Qyt 8900r
  9. Jul 27, 2020 at 11:04 AM
    #1629
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I see some Meso map lights in your future.....
    Taco_Cabal likes this.
  10. Jul 27, 2020 at 3:46 PM
    #1630
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I'm on vacation down south, and decided to put the GPS on my Uniden SDS 200. Thanks to the miracle of Amazon I was able to order that and have it shipped to my son's house so it was waiting for me when I got there. About a 5-minute quick and dirty install and setup and it's working great. When we get back home next week I'm going to install my new Icom 2730a and do a permanent install for the GPS. The goal will be to hide all wires.
    I have a DSM from Taco Garage waiting for me at home as well and a short stubby mount with a 17 mm ball. Again the goal will be to get everything mounted with the minimal number of wires showing.
    Obligatory photos of the finished product will be posted.
    Tullie D likes this.
  11. Jul 27, 2020 at 5:48 PM
    #1631
    NihongoTaco
    NihongoTaco Well-Known Member
    Cyrus
    Stock 2011 Toco
    wheel spacers
    Hello I’m very new to radios and just upgraded from an antenna on a magnet to a 4’ Firestik antenna I mounted on my hood using the Relentless Fab mount. I have a 3.5in spring on as well, but am getting very high SWR readings, any ideas as to what I’m messing up?
  12. Jul 27, 2020 at 6:54 PM
    #1632
    93yotasr5
    Sacramento
    What length coax cable did you go with?
    Does the antenna have a tunable tip?
  13. Jul 28, 2020 at 5:05 PM
    #1633
    NihongoTaco
    Cyrus
    Stock 2011 Toco
    wheel spacers
    My coax cable is 18’, and yes it does have a tunable tip which I’ve played with and still have gotten high SWR, in the 3s.
  14. Jul 28, 2020 at 7:12 PM
    #1634
    93yotasr5
    Sacramento
    Do you have any pics of the set up?
    Is the CB grounded properly? How about the antenna? For the excess coax cable, it should be in a figure eight configuration. (just reading a few things about your issue)
  15. Jul 28, 2020 at 7:16 PM
    #1635
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Do you have bare metal from the bracket touching the body? And same for the antenna fitting to the bracket?
    ancient11 and medic2230 like this.
  16. Jul 29, 2020 at 12:24 AM
    #1636
    NihongoTaco
    Cyrus
    Stock 2011 Toco
    wheel spacers
    My set up is the same as the third assembly in the figure above, so the one to the far left. My extra coax cable which is not much is not coiled I read that coiling may cause feedback but I could be wrong. As for my ground the bracket attaches to the bolts which attach the hood to the hood hinges. I read somewhere that if the paint is too think then this could cause a poor ground to the frame of the truck, anyone know if this is true?
  17. Jul 29, 2020 at 12:46 PM
    #1637
    MikeyD.25
    MikeyD.25 Well-Known Member
    You may have to remove some paint and get to bare metal for good ground continuity. Bad grounds/grounding is the major cause of high VSWR. :hattip:
  18. Jul 29, 2020 at 12:49 PM
    #1638
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
    where did you get those rj45 sockets for the small push button? All the ones I keep finding are the wrong size for that socket
  19. Jul 29, 2020 at 1:25 PM
    #1639
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Firestick also makes a 4 foot no ground plane antenna...... Before you start scraping paint off of everything.
  20. Jul 29, 2020 at 1:27 PM
    #1640
    golfindia
    Yes.
    pickup truck
    Bad grounds can also cause great SWR. A dummy load is perfect 1:1 match.
    m603holden likes this.
