Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Jan 24, 2021 at 11:32 AM
    #1801
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Ok, I need some new antenna help here. Ive gone through 2 firering cables, They keep breaking right at the joint where the antenna connects. There is no stress there, the wire is loose, and its not moving, but it keep breaking. SO I have removed my radio, pulled the antenna out and am searching for a better antenna location.
    My old antenna was mounted above the tail light on one of those rear spot light mounts. Im trying to decide if I should mount it in the bed, or switch to a ditch light mount.
    If I do a ditch light mount, I dont want to keep using the low profile fire ring mounts, so which ditch mount will fit the whole antenna cable plug.
  2. Jan 24, 2021 at 11:38 AM
    #1802
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Is this for CB? You can always get a ditch light bracket extension to move the antenna away enough for a pl259 to a traditional stud.
    If your talking VHF/UHF I’ve done a Rago NMO extension bracket and run a cheap OPEC pl259 NMO and connected directly then waterproofed the connection.
    I’m also not a fan of firerings. Both the 2 I owned eventually let a ton of water end and corroded to heck. If you even slightly overtighten them they warp.
  3. Jan 24, 2021 at 11:45 AM
    #1803
    5nahalf
    Erik
    Minnesota
    Its for CB. Im not a huge fan of the extension just from a looks standpoint. I dont plan to run ditch lights so I was hoping to to have a slim look.
    Maybe I will just get a nice mag mount and put a port plug behind the rear seat. I only use the CB on road trips anyways.
  4. Jan 24, 2021 at 11:59 AM
    #1804
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Your best bet is to google ham radio and antenna testing.
  5. Jan 24, 2021 at 2:27 PM
    #1805
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    The first thing you need is a SWR meter that covers the ham frequencies.
    k8md likes this.
  6. Jan 24, 2021 at 8:49 PM
    #1806
    5nahalf
    Erik
    Minnesota
    Ok, new plan and its fucking stupid, but if it works its going to be amazing.
    So I have this diamond powerup/down antenna mount. Its amazing, but its I never had a good place for it. I had it on my bed rail, but was always afraid it would either grow legs, or get hung up on a load. So, I got the idea that putting it on the roof would be pretty cool, then I realized that my OEM roof rack might actually have the space inside of it for me to mount the electronics of the power antenna inside! All that will stick out of the side is the little arm that rotates and holds the antenna. I just need to decide if I want the antenna on the inside edge of the roof rack, or the outside edge.
    So, here is the inside of the diamond power antenna kit, I matched it up to my roof rack and it looks to fit perfect inside the front or rear of the rack. Im going to pull my roof rack this summer to wrap my roof, so perfect time for me to get this thing installed along with some side mounted lights.
    bagleboy likes this.
  7. Jan 25, 2021 at 4:48 PM
    #1807
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I assume the end bit comes off to feed through a fender. Can you get a grommet on there to seal the pivot hole?
  8. Jan 25, 2021 at 4:59 PM
    #1808
    5nahalf
    Erik
    Minnesota
    Should be able, its just a metal shaft. Im going to swing by the hardware store to find a grommet that will fit this weekend.
  9. Jan 25, 2021 at 8:13 PM
    #1809
    bagleboy
    Scott
    Norcal, Santa Rosa
    Check in the electrical section wire nuts etc.
    5nahalf[QUOTED] likes this.
  10. Jan 27, 2021 at 12:40 PM
    #1810
    Seth2197
    Seth2197 Well-Known Member
    2020 Tacoma TRD Off-Road Premium DCSB
    So since I've got my radio installed I've been having issues transmitting. The radio is a Uniden CMX760. It seems to receive fine, I can hear others transmitting and I can hear the weather. When I try to transmit I hear squealing coming from the speaker on my mic, I seem to be transmitting a squeal as well. It also seems to then stick in TX mode even after I release the button.
    I checked and I believe I have a good ground, I have the antenna mounted in the front of the bed near the cab, and I ran a wire from my mount to a bolt on the frame. Mount is grounded down where the antenna stud goes, and where the wire is screwed in. When I check with my multimeter it says I have very low resistance from my antenna to my negative battery terminal. I checked unplugged the radio and tested the coax, I don't seem to have any shorts. I even ordered a second CMX760 thinking the first one was dead. Exact same issue. I can't work out what's going on for the life of me. I tried checking SWR with my meter and it doesn't seem to check right with the squealing, the antenna will kind of move all over the place but I did my best to get it as good as possible. The squealing is also kind of an on and off beep, which is where I was having the main problem checking SWR.
    If anyone has any ideas, I would really appreciate it.
  11. Jan 27, 2021 at 12:42 PM
    #1811
    5nahalf
    Erik
    Minnesota
    You need a good ground that is short. I had to run four 14gauge wires from my antenna mounted there just to get a halfway decent SWR. I have the same radio btw.
    Seth2197[QUOTED] likes this.
  12. Jan 27, 2021 at 12:50 PM
    #1812
    Seth2197
    Okay, I tried to make it short as possible but it might not be short enough. Not sure what gauge wire I'm using either, might need to go thicker. Any recommendations on what to ground it to? I have it grounded to one of the bolts that secures the brake lines. Its maybe 4ft of ground wire, from the top of the bed right to the frame.
    I'd like to keep it in the bed but I have to move it somewhere I suppose I have to. Thanks!
  13. Jan 27, 2021 at 12:57 PM
    #1813
    5nahalf
    Erik
    Minnesota
    Thats the exact spot that I grounded to also. But yeah, it was never really good enough of a ground due to the length of the wire, even with 4 wires grounding it it was never enough. I moved my antenna to the back of the bed and had it grounded to the tail light bolts and it worked much better. Get a swr meter and check what your levels are. They are pretty cheap.
  14. Jan 27, 2021 at 2:01 PM
    #1814
    Doc62
    Dave
    SE Pennsylvania
    You may want to use flat braid for the ground straps.
    Seth2197, Durango95 and HisDad like this.
  15. Jan 28, 2021 at 5:48 PM
    #1815
    Seth2197
    So kind of interesting, you were right about it being the ground. I did some research on why a long ground is bad and it turns out, when a ground is long it can act like an antenna and mess with your actual antenna. I switched my ground wire to an 8 gauge really thick wire, and looped both ends through a RF choke. I also threw an RF choke on my coax and the power cable for the radio running to the battery.
    It works like a dream now, I was picking up signals from across town. My SWR was 1.5 after I tuned the anatena. I might still move it down the road but I'm happy with it for now. Thank you so much!
    CliffyDeuce, k8md and 5nahalf like this.
  16. Jan 28, 2021 at 6:33 PM
    #1816
    Doc62
    Dave
    SE Pennsylvania
    Ground currents are surface currents. That’s why flat braid works better than regular wire. As you saw, a thick wire worked because it had more surface than a smaller gauge wire. I use 1” flat braid to ground my HF screwdriver antenna on another vehicle to the vehicle frame with good results.
    Seth2197 likes this.
  17. Jan 28, 2021 at 9:35 PM
    #1817
    FishN'Taco
    FishN'Taco Well-Known Member
    lucas
    San Diego, CA
    18 TRD OR DCSB
    Fox 2.5 Ext Travel w/ Adj Reserviors (3") ACCUTUNED Camburg Uniball UCA Deaver u402 stage 1 Leer 100XQ Front Runner Slimline II Rack Baja Designs Onx6+, SQ-Pro, SQ-Sport Switchpros 9100 285/70/17 Falken AT3W on 17 Method 305 NV RIGd Ultraswing Powertank 10lb
    any pics of the 3rd brake ligt with antenna? thanks
  18. Jan 28, 2021 at 11:27 PM
    #1818
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
    just be careful screwing into that plastic there because that is where your lower vents are routed, for the front and rears
  19. Feb 8, 2021 at 3:08 PM
    #1819
    nats
    nats Well-Known Member
    Lakewood, CO USA
    '10 TRD Sport DCSB
    (this will change)
    A quick question about others' experience:
    Mesocustoms 3rd brake light w/ NMO mount, I'm fairly certain that I'd just rip this off or bend my cab the first time I tree-smacked the antenna.
    Does anyone have direct experience with this mount in the trees (or a drive-thru)?
    FishN'Taco likes this.
  20. Feb 8, 2021 at 3:15 PM
    #1820
    JdevTac
    Josh
    MD/GA
    2nd gen
    Hard to say what would happen if you whacked it on a limb. I don’t think your cab would bend but the brake light housing might warp if you had a non-spring antenna. Definitely would want an antenna with a spring. Even with a spring after enough hits you might see the plastic fatigue and break. It’s a lot of leverage to put on what are essentially 2 screws into plastic nut inserts to the roof. The other issue is that spot means you have no real ground, and would need to run a 1/2 wave antenna or a ngp antenna.
    I had one briefly on my 2nd gen before I sold my truck. I probably wouldn’t run one if I saw a lot of forest roads. Good for the desert or open land though.
    Personally I’d just put an NMO thru the roof itself with a backing plate. If you do it using a 3/4 greenlee punch it will look like a factory hole.
    Gunshot-6A likes this.
