Clean VHF/CB radio installs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FoleySwampPlotts, Feb 10, 2016.
  1. Jun 19, 2021 at 4:15 PM
    #1961
    pmoore4321
    pmoore4321 Well-Known Member
    San Juan, Puerto Rico
    2021 Tacoma OR
    Your SWR meter is screaming for help.
  2. Jun 19, 2021 at 4:33 PM
    #1962
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Where should the strap be?
    I removed it and retested. The SWR meter is acting less dump but the SWR readong is maxed out. There is no ground at all without the strap.
  3. Jun 19, 2021 at 4:38 PM
    #1963
    pmoore4321
    2021 Tacoma OR
    Is the mount grounded? Only way to know for sure is to check for continuity with a meter. A quick and dirty way to check is to disconnect your ground from the radio, but not the positive lead. If the radio still comes on, you have ground at the mount. You can add that strap if you want, but it might be easier to just try to get metal to metal contact at the mount itself (ie, remove paint, etc.).
    I've never used a "fire ring" antenna coax, but it looks like it's not grounded at the mount.
    HisDad likes this.
  4. Jun 19, 2021 at 4:40 PM
    #1964
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    The mount is not grounded. I was trying to prevent rust by using the strap instead of grinding off power coating on the mount.
  5. Jun 19, 2021 at 4:53 PM
    #1965
    pmoore4321
    2021 Tacoma OR
    I see. Yeah, you can do that. I think you have the right idea. You just had the strap connected directly to the antenna.
  6. Jun 19, 2021 at 5:06 PM
    #1966
    pmoore4321
    2021 Tacoma OR
    I checked out the "fire ring" mount. Looks like you need to clear away a little paint from the bottom of the mount between it and the fire ring. Looks like that's how the coax braid grounds.
    C41n likes this.
  7. Jun 19, 2021 at 5:14 PM
    #1967
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I tried this shortly ago (was trying not to do this), and removed the ground strap after you told me I was shorting it. Also went ahead and stripped some paint from the the mount meets the truck on both sides. I still don't think I am getting a ground. I am out of time for this right this moment, and I will have to come back to it. Appreciate your help, thank you.
  8. Jun 19, 2021 at 5:21 PM
    #1968
    pmoore4321
    2021 Tacoma OR
    I think one of the issues is that the "fire-ring" is really made for an un-painted mount. If you look at the top of the fire ring (the side with the raised, white plastic centering section) there is an exposed steel circular ring. That ring, I assume, is connected to the coax braid. You need that ring to make metal to metal contact with the bottom of the bracket. That should solve the grounding problem. It may or may not lower your SWR.
    HisDad and C41n like this.
  9. Jun 20, 2021 at 8:17 AM
    #1969
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    I wanted a no-drill solution for mounting antennas on the roof. I bought a couple of NMO mounts from Breedlove (who are just fantastic) and got a 73 thou sheet of aluminum plate from a metal shop. Two 3/4" holes later, et voila.
    I ordered some studs that fit into the slots on the Prinsu crossbars, I hope they show up soon. I will mount the plate on the underside of the crossbars. I will be able to just unscrew the antennas and put caps on the NMOs, then I will have unrestricted use of the roof rack because the mounts will not project above the crossbars.
    If there is any interest, I'm happy to make a dimensional drawing and post it.
    I was initially going to mount my little tarheel ii screwdriver antenna up there but whereas I would be okay if the two whips shown got mangled, I would cry if I sheared off the very expensive tarheel in some parking garage, so I think I'll compromise on ground plane and just mount that one using a bed corner mount.
    Gunshot-6A, BillW, Sand Dog and 3 others like this.
  10. Jun 20, 2021 at 11:23 AM
    #1970
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    That ground wire is shorting your antenna directly to ground. That's why your SWR meter is pegging the needle. Keep doing that and you'll smoke the the RF out put transistor.
    This diagram at the Firestick website shows the different type of stud mounts. The fire ring doesn't need a separate ground, but you will need to make sure that there is bare metal for it the ground ring to make contact with.
    These instructions show how to install the fire ring mount. There is no ground wire installed.
  11. Jun 20, 2021 at 11:51 AM
    #1971
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Would the strap work if on the other side of the fire ring instead? On the raised shoulder side. Then it could act as the bare metal to metal connection needed.
    Coupler
    Lock washer
    Washer
    Plastic washer
    Mount
    Ground strap with hole enlarged to encompass raised plastic insulator and touch metal shoulder
    Fire ring, plastic sticking up
    Bolt
  12. Jun 20, 2021 at 2:53 PM
    #1972
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    You are making the grounding strap a part of the antenna. You will need to tune the antenna to account for the longer ground element. It might work and it might not. Good luck.
  13. Jun 20, 2021 at 3:20 PM
    #1973
    pmoore4321
    2021 Tacoma OR
    Yes it would. That's a good idea.
  14. Jun 20, 2021 at 3:43 PM
    #1974
    bagleboy
    Scott
    Norcal, Santa Rosa
    Is that why they suggest using a coax ground for the mount?
  15. Jun 20, 2021 at 4:19 PM
    #1975
    foy1der
    W1FOY
    2017 OR DCLB
    I don't know the answer to that.
    I would try using the fire ring as intended. Unless of course you want to play around with it. I can certainly understand where you are coming from if that's the case.
    HisDad likes this.
  16. Jun 20, 2021 at 4:19 PM
    #1976
    HisDad
    Texas at last
    The antenna is designed not to need a ground strap. As foy1der says it might change the SWR of the antenna.
    Do what you think best, but Firestick designed the antenna that way for a reason.
  17. Jun 20, 2021 at 4:20 PM
    #1977
    HisDad
    Texas at last
    "Tune for maximum smoke." as a friend of mine who is a retired electronic engineer likes to say.
    Gunshot-6A likes this.
  18. Jun 20, 2021 at 4:28 PM
    #1978
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    a lot of different units everyone's using. i've got an aftermarket stereo, which opens up a dash slot for something. been thinking about a uniden bearcat 980.
    https://smile.amazon.com/Uniden-Cha...keywords=uniden+bearcat&qid=1624231584&sr=8-4
    is there something about those units that no one likes them? just curious before spending the money on something that doesn't work so great.
  19. Jun 21, 2021 at 12:14 PM
    #1979
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    On a 3rd gen? Seriously - I looked to see if I could downgrade to a single din and get a radio in there, were you able to do that!? I'd love to! :D I'm about to buy one of these:
    https://smile.amazon.com/President-...keywords=small+CB+radio&qid=1624302798&sr=8-4
    In the customer images there's actually one in the phone cubby of the tacoma. I don't use that for phones or really anything, so might as well put a radio there :notsure: but, if you can get it in the dash with a single din that would be bitchin'. Then I can do a CB and GMRS :D
  20. Jun 26, 2021 at 5:46 PM
    #1980
    soundman98
    NW Indiana
    yeah, i've already got my pioneer head unit installed(my first rule of vehicle purchases is that i can install my own radio, wouldn't have a 3rd gen if i couldn't), and the sony above it is a placeholder for better things!
    scosche makes a glossy kit(like installing a mirror in the dash, bleh), metra's kit was on indefinite backorder for 1-2 months, and this random Amazon kit matches the oem finish best
    https://smile.amazon.com/dp/B01M7UE2BQ?ref=ppx_yo2_dt_b_product_details
    the main thing is that i wanted to make sure was that there wasn't some serious problem with those bearcats that all the experts knew about but weren't saying!
    GarlicFarts[QUOTED] and shiftd like this.
