cleaned maf now high idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by 604YOTA, Mar 27, 2014.
  1. Mar 27, 2014 at 9:47 PM
    604YOTA
    604YOTA [OP] Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    So I cleaned my maf and throttle body was dust and grime.. now when it idles in neutral it sits at 1300rpm and in gear 1000rpm... my search function isn't working on my phone...
    Any suggestions?
  2. Mar 27, 2014 at 9:49 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Disconnect the negative battery cable for about 10 mins
    That will let the ecu reprogram the a/f mixture.
  3. Mar 27, 2014 at 9:55 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Ah thanks unplugged it but it was like 30 seconds. ..will try again
    Cheers
  4. Mar 27, 2014 at 10:00 PM
    Matic
    Tricky Dick
    Easley, SC
    Maybe its the positive cable. I forgot.
  5. Mar 28, 2014 at 9:24 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    So I unplugged the positive and the rpms dropped to 1100 when in neutral and 800 in gear something isn't right?
    Maybe a air leak?
  6. Mar 28, 2014 at 10:43 AM
    Matic
    Tricky Dick
    Easley, SC
    Well. I was thinking that over the years the sensor and tb had gotten dirty so the ecu was compensating and adjusting the a/f. So when you cleaned everything out, It needed reset because everything was more free flowing.
    Unplugging the pos just helps the ecu recalibrate a little faster but it might take a few miles for it to actually figure out where it needs to be.
    How many miles have you driven it since disco on the pos wire?
    Recheck all the vacuum hoses on what you cleaned? Maybe you knocked something else loose.
  7. Mar 28, 2014 at 12:29 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Hmm yeah I've only done 20miles and that's to work I'll 're check everything when I get home
  8. Mar 28, 2014 at 2:16 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Let it warm up and gun it a few times! Oh yeah. Why did you clean maf to begin with?
  9. Mar 28, 2014 at 2:22 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Cuz I haven't ever done it and the amount of dirt in my after market system felt it was due time. We have had salt trucks out this winter and wanted none of that in my engine.
  10. Mar 28, 2014 at 3:23 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You got to let the ECM re-learn everything. Dont be surprised if your truck stalls out when turning on the AC shortly after resetting the computer.
  11. Mar 28, 2014 at 5:59 PM
    Andy.G
    Andy
    Virginia
    Yeah,they salt the shit out of this place. Pre salt even before snow. Oh yeah,sand also. That sand is terrible on hood paint. I think your truck will clear itself up with some driving.
  12. Mar 28, 2014 at 6:21 PM
    Madjik_Man
    Colorado Front Range
    You can also pull the ECU fuse for 15 mins, then put it back in.
    After I cleaned my MAF and TB, and doing that ^, it took a few start ups, driving, turing the truck off, etc before the computer relearned everything.
  13. Mar 28, 2014 at 6:38 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    All is normal now thanks guys
    Rpm is down to a normal 600 and smooth
    Took it for a long drive after work and cleared it up.
  14. Mar 28, 2014 at 8:07 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    mine has not changed since October but I also have not pulled the -neg cable since I cleaned the MAF/outside TB back in September.
    I was planning on pulling the whole TB and cleaning it along with the IAC this weekend but you know, rain decides to come to town....sigh (no garage either)
    I'll try the battery cable but I've driven over 3k miles since October with no change in sometimes high rpm. I've always used an oiled filter and my MAF was brown coated which is one of the reasons I did it
