Cleaned MAF/Throttle body - Now hard cold start/low idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by tawd77, Feb 15, 2010.
  1. Feb 15, 2010 at 8:31 AM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    I have a 99 taco 2.7l and I cleaned the MAF sensor with MAF cleaner, and then hosed down the throttle body really good with carb cleaner. Now I have some problems.
    Now it doesnt like to start when its cold, unless you floor the throttle, then it will start with a puff of gassy smoke out of the exhaust. and the idle use to be a little over 1k rpm when it was cold. Now it just sits at about 800rpm. There are NO check engine lights. I changed the plugs hoping that I just fouled them out, but no go. Any ideas what controls the COLD idle level, and fuel mixture? Maybe I damaged the MAF? Thanks for any help!
  2. Feb 15, 2010 at 8:34 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    How did you hose it down? When TB was still on the truck?
  3. Feb 15, 2010 at 8:52 AM
    tawd77
    tawd77 [OP] Member
    Kansas
    stock 2.4/manual
    I took off the intake tube, and held the butterfly open and sprayed the throttle body/intake manifold with carb cleaner. Then, reassembled with the intake tube, and MAF, with no filter hooked up, and started the truck, raised the idle, and sprayed carb cleaner next to the MAF sensor (trying not to hit the actual sensor part) in the center of the intake tube, and sprayed probably a 1/4 can through the intake tube with the truck running.
  4. Feb 15, 2010 at 12:47 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i clean my MAF sensor pretty regularly but that's it, and no issues with starting...
    my truck has always idled around 500...
    over 1,000 at idle is high...
    what did you use to clean the MAF sensor?
