Cleaned throttle body, now engine revs around 2k RPM
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bangz_yo_mama, Oct 17, 2019.
  1. Oct 17, 2019 at 10:54 PM
    Bangz_yo_mama
    Bangz_yo_mama [OP] New Member
    Christopher
    98 TRD 4x4 5-speed
    Bone Stock
    Cleaned throttle body, now engine revs around 2k RPM. So I replaced MAF and IACV and most vacuum lines. Anybody ever done this before?
  2. Oct 17, 2019 at 11:07 PM
    Strbass
    Strbass Member
    Nick
    Why did u replace all that? Most of the time you just need an idle relearn from the manufacturer. Let the dealer do your next decarb service.
    Black DOG Lila likes this.
  3. Oct 17, 2019 at 11:08 PM
    eon_blue
    Azusa, CA
    High idle is expected after cleaning the throttle body. Mine idled at ~1200 -1500 rpm after I took mine off and cleaned it. Normally the ECU will readjust after a day or so of driving and it will go back to normal.
  4. Oct 17, 2019 at 11:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Then again it might be as simple as a vacuum leak.
  5. Oct 18, 2019 at 2:42 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    How did you clean the throttle body, completely removed it or just sprayed some crap in?
    GQ7227 likes this.
  6. Oct 18, 2019 at 7:48 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    What running condition were you attempting to fix by cleaning the tb?
    Wyoming09 likes this.
  7. Oct 18, 2019 at 7:54 AM
    1997tacomav6
    Denver
    One issue that also happens is the throttle body butterfly after many miles will wear a spot
    on the throttle body inside wall were it touches. When the throttle body is dirty the carbon fills
    in the low spot. When you clean the dirt out now you have a gap inbetween the butterfly and the wall
    that lets air sneak by that makes the idle higher.
    Only fix for this is the have the throttle body bored and new butterfly or new throttle body
    If you can see a gap inbetween the butterfly and the wall after cleaning ,that’s your problem.
    Your butterfly should be tight like this with no gap
    This is a common problem After cleaning the throttle body
    970btu, Strbass, Xbeaus and 1 other person like this.
  8. Oct 18, 2019 at 8:04 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Make sure the IAC port is clean. I cleaned my tb only once and crud went down in there and had a high idle. Removed IAC and cleaned everything and it idled perfect.
    TWJLee likes this.
  9. Oct 18, 2019 at 8:04 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I don't have any issues, but I would love to send my throttle body off to the site below. I've read on this forum and the 4Runner forum some really great reviews.
    http://www.maxbore.com/
    cruiserguy likes this.
  10. Oct 18, 2019 at 8:07 AM
    jammer
    Ben
    Bentonville, AR
    I had this same issue when I removed and cleaned mine. I didn't see it in your post and maybe you did this, but disconnect the battery for about 10 min.
    I did this and drove on the highway, and in town. Afterwards, it settled down to the normal idle.
  11. Oct 18, 2019 at 8:20 AM
    1997tacomav6
    Denver
    The photo above is what my throttle body looks like AFTER maxbore bored it.
    Highly recommend, but he works on 1st come 1st server so it took 3 weeks from shipping date to return shipping date for me
    jammer[QUOTED] likes this.
  12. Oct 18, 2019 at 8:25 AM
    jammer
    Ben
    Bentonville, AR
    Curious if you could tell any difference afterwards besides fixing the idle issue?
  13. Oct 18, 2019 at 8:28 AM
    1997tacomav6
    Denver
    Yes I could just a little but that’s because I have a supercharger so it’s letting a little more air to pass at high rpms
    If not superchargered probably not
  14. Oct 18, 2019 at 8:39 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you and your fancy supercharger :cheers:
  15. Oct 18, 2019 at 9:38 AM
    eon_blue
    Azusa, CA
    interesting, that makes sense though for higher mileage trucks. Might be what the OP is experiencing too since his is so high.
    That or a vacuum leak if he forgot to reattach a line or one of them cracked, gasket between the TB and intake failed, etc.
  16. Oct 18, 2019 at 10:25 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    At 240,000 or so miles the throttle body on mine was cleaned one time when replacing the IAC valve that failed completely .
    The older I get the more I like if it is not broke leave it be.
    AmherstAndy, kigmob and GQ7227 like this.
  17. Oct 18, 2019 at 10:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you run one of them fuel cleaners/additives regularly in the tank?
  18. Oct 18, 2019 at 10:43 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Maybe once in 125,000 miles
    GQ7227 likes this.
  19. Oct 18, 2019 at 11:08 AM
    Faxmachine2
    Faxmachine2 Well-Known Member
    Nashville TN
    1998 Tacoma 3.4 5spd
    OME
    So on a high mileage vehicle maybe...
    a. Just stick to spray without the wiping out?
    b. Wipe out but avoid the "carbon seal"?
    c. Leave completely alone?
  20. Oct 18, 2019 at 11:16 AM
    Trucknorris
    Trucknorris Well-Known Member
    2017 sr5 double cab 4x4
    Several
    Just run some seafoam in the tank it will clean everything
    badone likes this.
