Cleaned throttle body, now engine revs around 2k RPM
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bangz_yo_mama, Oct 17, 2019.
  1. Oct 18, 2019 at 12:14 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    That's not going to clean carbon buildup on the throttle body or carbon deposits in the engine, running it through the fuel tank is good for the fuel system though and injectors. To clean carbon out of the throttle body and engine with Seafoam you want to run it through the intake in small sprays while the engine is running at ~1200 RPM. They make a spray can version that works well for this
    jammer likes this.
  2. Oct 18, 2019 at 12:17 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    If the throttle stop is adjusted correctly it should prevent the throttle plate from wearing the throttle bore. If not set correctly the plate will slam into the bore every time you let off the gas.
  3. Oct 18, 2019 at 12:22 PM
    Faxmachine2
    Faxmachine2 Well-Known Member
    Nashville TN
    1998 Tacoma 3.4 5spd
    OME
    I'm sure most high milers can assume that the throttle stop has worn along with the throttle bore? I feel like the right thing to do on my 225k is a light spray and pray
  4. Oct 18, 2019 at 2:36 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    I run marvel mystery oil from time to time in the fuel.
  5. Oct 18, 2019 at 2:51 PM
    ccotner112
    ccotner112 Well-Known Member
    Saint Louis Missouri
    2018 Tacoma TRD Sport
    17' TRD rims/BFG Ko2, OEM Roof Rack, TRD Pro Grill, Locker down console , Snugtop Rebel, lots MESO mods
    I just went out and drove like a race car for about 10 min and the idle went back to normal after removing throttle body and cleaning.
  6. Oct 18, 2019 at 4:40 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    The throttle stop screw should be checked and adjusted as routine maintenance. OK, I'm guilty I don't check mine. :oops:
    cruiserguy likes this.
  7. Oct 18, 2019 at 11:30 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive had those stops come loose and throw idles off @what road truck had his move and the truck was stuck idling around 2k
  8. Oct 19, 2019 at 6:38 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I managed to clean the TB and IACV during the engine job without causing a problem. I had the TB off the engine while cleaning it. The battery was out of the truck during all of that time. Hooked it all back up and it started right up. It idles so good now that I don't want to touch anything.
    jammer likes this.
  9. Oct 19, 2019 at 7:56 PM
    Vaushaus
    Vaushaus トヨタのトラックはすごい
    Vancouver, British Columbia
    1998 3.4L 4x4 Auto
    Bilstein + Eibach Coilovers, OME Dakars w/ AAL, 33" Wranglers on American Racing AR23 wheels
    Another idea... I may be wrong here.
    If OP fully removed the Throttle Body for cleaning, that would've required disconnecting the throttle cable that connects to the gas pedal.
    Is it possible to reinstall the cable incorrectly and generate a higher idle rpm?
  10. Oct 19, 2019 at 8:04 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Doc, I'm shocked and disappointed :rofl:that emoji got me laughing hahaha
    DrZ[QUOTED] likes this.
  11. Oct 19, 2019 at 10:51 PM
    Empty_Lord
    Dan
    if it is adjusted wrong yes it'll be open. very possible this is the case here.
