Cleaning Battery Corrosion - Computer Reset?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by coleslaw26, Oct 9, 2023.
  1. Oct 9, 2023 at 12:42 PM
    coleslaw26
    coleslaw26 [OP] Active Member
    Wyoming
    2021 Tacoma SR
    Hi all, I'm relatively new to car maintenance but am trying to take more on to save some cash. Something I need to do is clean a bit of corrosion off my 2021 Tacoma SR battery. I've been checking some of the threads on here and am running into stories ranging from major computer resets to blown fuses. I didn't think cleaning corrosion would be so risky, but I want to make sure I do it right the first time so I don't find myself with a major repair bill. Anyway, any advice y'all may have is appreciated.
    Thanks!
    Stevie17 and hiPSI like this.
  2. Oct 9, 2023 at 12:48 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Cleaned my old one just before replacing it.
    Remove Neg. then Pos. terminal.
    (Pos. then Neg. to reconnect).
    Dissolved a little baking soda in some water and cleaned the post and terminal with an old toothbrush.
  3. Oct 9, 2023 at 12:49 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I clean my terminals and cables with one of these.
    Stevie17 and TRDRed like this.
  4. Oct 9, 2023 at 12:50 PM
    coleslaw26
    Wyoming
    2021 Tacoma SR
    Awesome, thanks for the tips. Have you had any issues with all of the electronics/computer on the vehicle being reset? I've read about people having issues with the truck needing to "re-learn", but I just have an SR so I didn't think my tacoma had any overly fancy features like that.
  5. Oct 9, 2023 at 12:54 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    How bad is the corrosion?
    It’s not that old unless it’s filthy or over charging or has an issue.
    You can just mix up some backing soda in water and pour it on the terminals, it’ll fizz and the acid-base reacts then rinse it off thoroughly......without disconnecting the cables.
    What I found on my 17 is removing a cable for a short time will reset both trip odometers, the rest is unaffected......(short duration).
    I’ve never removed the cable for a long time (10 minutes+).
  6. Oct 9, 2023 at 12:57 PM
    coleslaw26
    Wyoming
    2021 Tacoma SR
    The corrosion isn't too bad at all, just something that the dealer noted last time I had my truck checked out and is on my to-do list now. I also live in Wyoming and am frequently off-the-grid, so I want to keep my battery in top shape.
    I can try to keep the process to under 10 minutes, but can't be sure. A reset of trip odometers is fine (same with radio presents, etc.). I just don't want to turn the truck on to find there's some major electrical reset that requires a dealer visit.
    Thanks for the continued advice everyone.
    OBXPaul, Stevie17 and helix66[QUOTED] like this.
  7. Oct 9, 2023 at 1:06 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    I hear you and good to be proactive.
    The trips will zero on any break, but when I changed my battery at advanced autos parking lot everything remained.
    I use trip 2 for oil change, but also set the reminder in the maintenance app, which all stayed.
    I know they make those cigarette lighter/9v battery adapters to prevent loss.....I never tried one.
    Get those red and green felt washers and they concern with dielectric grease, that should prevent any buildup.
    Stevie17 likes this.
  8. Oct 9, 2023 at 1:07 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    A periodic reset is healthy. You aren't going to hurt anything.
    Make sure the terminals are snug.
    Loose connections can cause an arc, also creating corrosion.
    Stevie17 and ToyoTaco25 like this.
  9. Oct 9, 2023 at 1:12 PM
    coleslaw26
    Wyoming
    2021 Tacoma SR
    Ok this all sounds good then. Appreciate the feedback everyone.
    I have some battery cleaner spray I plan to use, and then I'll coat the terminals in a bit of Vaseline.
    I did read about those 9V battery adapters, but if trip meters/radio presets is all that's at risk, I'm not super worried about those.
  10. Oct 9, 2023 at 1:23 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    something with a higher melting point would be better given your stated plan liquefies at body temp
  11. Oct 9, 2023 at 1:31 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I wouldn't dig too deep into the rabbit hole on this issue. If you happen to notice some corrosion, pour some coke on it until it disappears or is greatly reduced. Your truck is likely too new to have any issues requiring you to actually remove the connectors to address it and your battery will likely need replacing well before then.
    When it is time to replace the battery, just touch up the connectors with a battery terminal brush if you have one and reconnect.
    As for disconnecting, I didn't really notice anything get reset other than my trip meter and the truck knowing my driving habits (both very minor). Most head units will not reset in modern cars simply from disconnecting your battery briefly. Back in the 90's and 2000's, sure. But not these days.
  12. Oct 9, 2023 at 1:54 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Coke is good for cleaning rusty tools but the phosphoric acid that eats that rust will not neutralize the battery acid. Might spread it around more.
  13. Oct 9, 2023 at 2:02 PM
    RedWings44
    Michigan
    I've actually used the coke method in the past on a few different vehicles without issues spreading the battery acid around.
    It doesn't neutralize the acid per se, but does a pretty good job at dissolving it. But yes, you want something that's more of a base if you're concerned about neutralization of the battery acid.
    Stevie17 and bkhlrTaco's[QUOTED] like this.
  14. Oct 9, 2023 at 2:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I could be wrong, but I don’t think the corrosion on a battery terminal contains much acid. Rather it is the outputs of the chemical reaction of the acid and the terminal.
    In any case, it’s not something I’ve ever worried about on a newish vehicle.
  15. Oct 9, 2023 at 2:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get a rag and a can of Coca Cola. Soak a corner of the rag in the Coke. Wipe on the corrosion literally heavy. Wipe off excess. It's amazing.
    RedWings44 and Stevie17 like this.
  16. Oct 9, 2023 at 2:42 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. It works great. Just did it last month on my wife's vehicle. Did it many times the past 40 years.
  17. Oct 9, 2023 at 2:57 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I'm sure Coke cleans it up nicely. Sunkist would get you the same results.
    Was pointing out it doesn't neutralize.
    hiPSI and Stevie17 like this.
  18. Oct 9, 2023 at 4:10 PM
    coleslaw26
    Wyoming
    2021 Tacoma SR
    Only the positive terminal is showing some corrosion, so I may opt to take your approach and just leave the cables connected. If I do that, I have some battery cleaner spray I plan to use. How dry does everything need to be before restarting the vehicle? I imagine that some of the fluid could seep between the terminal and the cable hookup, which could be hard to dry with a cloth without disconnecting. Or am I overthinking things?
  19. Oct 9, 2023 at 4:27 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    It isn't risky. I have done it a couple of times (disconnect the battery)to clean up the terminals and the only thing that happens it the idle speed resets to a base-line value because the ECU resets to same with the power loss. You get irregular idle speeds for a little while until it re-adjusts.
    FWIW: Anytime I'm working on anything electrical in the truck, the key is off and out, and the negative cable is disconnected before I start.
    tiap and Stevie17 like this.
  20. Oct 9, 2023 at 4:30 PM
    Spankomatik
    Spankomatik Well-Known Member
    JD
    IL
    2021 celestial silver metallic AC SR SX 4x4 2.4L
    Fog lights, switch panel, cab storage platform
    Once you get it cleaned up, and your connections are all solid, spray a little bit of Fluid Film on the terminals so they don't corrode again.
