Cleaning blower and cabin filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Cid, Dec 19, 2016.
  1. Dec 19, 2016 at 9:23 AM
    El Cid
    El Cid [OP] Well-Known Member
    South Carolina
    11 Access Cab, 4 cyl, man., SR5
    That time of year if you have a 2011 model. May apply to a couple of others.
    The grille on top of firewall that permits air to enter ventilation system is poorly designed and allows leaves and other debris to get inside. Need to vacum it out periodically if leaves are a problem in your area.
    Toyota redesigned the grille later, but refuses to admit it is a design problem on some vehicles.
    Also, need to check the cabin filter. If there are leaves or debris on it, need to remove the filter and reach inside the blower housing with your fingers. If you feel leaves or debris, vacum it out. I attach a 6-8 inch section of old garden hose to end of shop vac hose to get into the blower housing. You can spin the blower with your hand to make sure you got all the debris.
    May need to repeat in spring for stuff that falls off trees then.
    TacoTronics and Spintly like this.
  2. Dec 19, 2016 at 9:26 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Trash that filter....they are cheap and can harbor mold spores
  3. Dec 19, 2016 at 9:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pull off the cowl cover.
    Cut a piece of fiberglass window screen a little larger than the cover.
    From the backside, use a hot glue gun to attach the screen to the cover.
    Trim excess with a razor, reinstall cover.
  4. Jan 12, 2017 at 1:28 PM
    TacoTronics
    TacoTronics War Eagle!
    Frankie
    Auburn, AL
    2014 V6 DCSB TRD Sport
    G4 Elite tonneau cover. Fuel Vapor 17s. Bilstein 5100s. Wheelers 1.5" Progressive AAL. AVID Sliders Line-X, Nokya Hyper Yellow Fogs, Fog Mod. Debadged, Ghost bedside decals, Line-X AVID Light Bar, ImMrYo mirror lift, Mattgecko LED bed lighting with remote, CSJumper2003's DTRL LED switchback mod, reversing, and parking. Nat's Rear Molle Panel for storage, HomerTaco grill.
    Just checked mine and there was mold all over the cabin filter... My hand is too big to fit into the filter area but I used a dust buster to get what I could out. New filter time I guess.
    inwood customs likes this.
