Cleaning foggy headlights..
Discussion in 'Detailing' started by oldblue1968chevy, Jan 20, 2013.
  1. Jan 20, 2013 at 10:18 PM
    oldblue1968chevy
    oldblue1968chevy [OP] Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    1999 Tacoma, the headlights are real foggy. Any DIY homeade tricks? Thought about some kind of wetsanding/compound maybe?
    Thanks!
  2. Jan 20, 2013 at 10:28 PM
    voodootruckers
    voodootruckers Well-Known Member
    Local mechanic showed me a little bit of brake fluid, a rag, and a low abrasive pad with a little bit of elbow grease. May need to reapply ever so often.
  3. Jan 20, 2013 at 10:29 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    You have to re-apply because it eats the protective layer so they get foggier quicker.
  4. Jan 20, 2013 at 10:36 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    ive heard of toothpaste working...
  5. Jan 20, 2013 at 10:37 PM
    Fightnfire
    Marysville, WA
    Yup, toothpase, vinegar, light rubbing compound.
  6. Jan 20, 2013 at 10:50 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
  7. Jan 20, 2013 at 11:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No matter what is used to polish them, they will fog again quickly unless protected.
    You can try waxing every weekend, but best is a quality clearcoat.
    Still need to wax regularly.
  8. Jan 21, 2013 at 12:02 PM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    So whats everyone do? Buy new ones? Cheapo ebay? Take em out, clean em and spraypaint clear coat them?
    thanks
  9. Jan 21, 2013 at 2:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    $160 for a pair of Depo housings on Amazon.
    Depo is the only manufacturer other than Toyota that I trust. I bought a set of Spyders for my wife's Rav4, and while they haven't leaked, the light pattern is terrible.
    Once you get the new ones in, keep them clean and waxed.
  10. Jan 21, 2013 at 2:13 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'd use some rubbing compound or something like the 3M headlight restoration kit, clear coat them and put them back on the truck.
  11. Jan 21, 2013 at 2:15 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I use this, works well, I wouldn't say months though. The headlight restoration kits work well (approx. $60). Those will last the longest and work the best, basically you are sanding and buffing and polishing it. I was going to try some thing on my dummy set soon and I'll let you know.
    Instead of buying the kits I will save some money and just try some extra fine wet sand paper, then polish. I'll post results.
  12. Jan 21, 2013 at 6:03 PM
    radredtaco
    radredtaco Member
    Nick
    Bergen County NJ
    05 access cab SR5 red
    Wetsanding then buffing is the real way to go on restoring headlights 100%. 3m headlight restoration kit is great. I just buffed my slighty foggy headlights on my 2005 with my porter cable 7424xp (da buffer), 5.5in foam cutting pad, and meguiars Ultimate compound. They came out amazing. I followed up with Meguiars #26 high tech yellow wax (my favorite). They werent that bad so wetsanding wasn't necessary.
  13. Jan 24, 2013 at 4:49 PM
    folmonty
    folmonty Active Member
    Monty
    NorCal
    05 PreRunner Sport (sold) 13 AC 4X4 (inbound)
    +1 to what radredtaco says. The 3M kit is the shit to use. $12 something on Amazon and $16 or so at Wallyworld. I used the folmonty (everything) in the kit due to a truck that sat outside for 8 years. Also did my wifes Chevy Equinox with the same kit. Only memo worth noting : be sure to tape the area around the lens well. You can't control the sanding that good and it will eat your paint or trim pieces PDQ leaving a mark. Kit is easy to use. Well worth the time / effort. Body shops get $125 or more to do this. Really helps appearance of the vehicle.
  14. Jan 25, 2013 at 12:59 PM
    radredtaco
    radredtaco Member
    Nick
    Bergen County NJ
    Pop the hood, tape off grill, and surrounding painted surfaces like the front fender and bumper, follow directions and your good to go!
  15. Feb 27, 2013 at 2:16 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    What about this fog building up inside my headlight? This bothers me so much!
  16. Feb 27, 2013 at 3:25 PM
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    How long does it usually take for headlights to start getting hazy? Is it just the sun that causes this?
  17. Feb 27, 2013 at 3:34 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Wet sanding and compound then clear coat them. Start with a 600 then 1000. clear them. you can wet sand with a 1500 after that then 2500. then buff them with a compound.
  18. Mar 17, 2013 at 11:04 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    2009 4x4 DC TRD Sport
    The only mod is a hole in my wallet!!!!!
    what are people using to clear coat their headlights?
