Cleaning K&N Filter-F'ed Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovemytaco, Jan 30, 2010.
  1. Jan 30, 2010 at 6:32 PM
    ilovemytaco
    ilovemytaco [OP] Well-Known Member
    So im done oiling the cone intake filter and it says the inside should also be red but mine isnt red at all on the inside...i didnt go up and down the pleats i went left to right...did i mess up?..should it be red inside?...should i add more oil? damn so complicated:(
  2. Jan 30, 2010 at 6:35 PM
    ilovemytaco
    exactly why im worried about oiling it more but if the inside should be red then maybe i have too little oil?
  3. Jan 30, 2010 at 6:38 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Don't worry about the color, just follow the oiling instructions and you'll be fine. Only you can know if you over oiled it.
  4. Jan 30, 2010 at 6:39 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    just lightly coat the top. just spray it evenly along the edges and it will be fine. If you think you over did it..use the saop and water and let it dry and try the spray again;) You dont want it to be soaking wet with the oil...its just to coat the outside so it traps the dirt on the outside of the filter
  5. Jan 30, 2010 at 7:16 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Uh do NOT use soap on the filter.................... use the K&N cleaning solution. If you just cleaned it you can just rinse it back down, let it dry, and re-apply. You should go along the pleats, and you should add enough oil to see some red on the intake side.. just lightly. Not enough oil is almost as bad as too much.... it won't filter much without the oil.
    Also, yes go with the grooves, not against them...
  6. Jan 30, 2010 at 7:29 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  7. Jan 30, 2010 at 9:23 PM
    ilovemytaco
    is this oiled enough?
  8. Jan 30, 2010 at 9:33 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You are the one making this complicated - as the procedure really isn't.
    If you are so worried about this, re clean, dry, and oil the correct way. If the instructions direct you to add oil until the inside of the cone is red, then add oil until the inside of the cone is red...
  9. Jan 30, 2010 at 9:36 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/75-16 KO2
    Looks a bit heavy to me, but it's hard to tell from a picture...
  10. Jan 30, 2010 at 9:37 PM
    ilovemytaco
    well actually im not really complicating it..i have the whole weekend where i wont need my truck so i want to get it right as well as entertain myself...if i didnt have the time i would have cleaned and oiled it and just threw it back in
  11. Jan 30, 2010 at 9:45 PM
    Fortech
    CANADA
    Your first post and I quote:"damn so complicated:("
    If you are still uncomfortable google "K&N Filter Oiling" or something. Not trying to be a smart ass here but you answered your own question in your first post. Only YOU can decide what you have done is sufficient or not as you can't tell squat over the internet with a picture, or see inside your cone filter where the apparent problem is located.
    Maybe these will help:
    http://www.youtube.com/watch?v=yrzuGZF8Emk
    http://www.youtube.com/watch?v=F5M0YykHUjM
    http://www.youtube.com/watch?v=Zf1WBZgyWiA&feature=related
  12. Jan 30, 2010 at 9:56 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    It looks fine
    Just wipe the rubber material down with a dry clean rag so you are sure no extra oil is on those parts.
    A new filter freshly oiled will be a pinkish red inside.
    After it gets used for a little over 250,000 miles like the one in my 79 Toy truck eventually went, no matter how long you soak it in the cleaner it will look black :cool:
    Don't worry if it looks a little dirty when you next check it, the K&N filter really well when dirty and nasty looking.
    I bought my first K&N the day Mount Saint Helens erupted and spewed tons of ash into the air, for weeks you could wash your truck and an hour later see a light layer of powder across the hood, many people running paper filters found the cheap paper did one of two things, plugged and became useless or didn't filter out the ash and let it into the motor, neither was good.
  13. Jan 30, 2010 at 10:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    You could sell your intake and get an AFE dry.......
