Cleaning old parts
Discussion in 'Technical Chat' started by SilverSeven, Nov 29, 2009.
  1. Nov 29, 2009 at 8:08 AM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    how? brake cleaner? i want to clean up my 97 steering box today but don't know where to begin. Does anyone have a solution? no pun intended.
  2. Nov 29, 2009 at 8:13 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    pressure washer may be a little better than brake cleaner.....not sure how the seals would react to the brake cleaner.
  3. Nov 29, 2009 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2 on the not knowing how the seals will fare. I have always used Gasoline, Brake Cleaner, or a sand blaster, but I have re built the parts after.....I would try the brake cleaner, and just be carefull.
  4. Nov 29, 2009 at 8:24 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  5. Nov 29, 2009 at 9:18 AM
    SilverSeven
    Jordon
    South Jurzee
    Should i just take the thing apart?
  6. Nov 29, 2009 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depends on how bad it is...If it doesnt need a rebuild, I would just clean it up to look pretty...
  7. Nov 29, 2009 at 9:21 AM
    JimBeam
    JB
    2015 Tundra
    i like my idea of buying a parts washer
  8. Nov 29, 2009 at 9:22 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....buy one....and bring it to mod day!!:D
  9. Nov 29, 2009 at 9:23 AM
    SilverSeven
    Jordon
    South Jurzee
    I dont know if it does or not.. it would be easier to clean each outer piece individualy then trying to fight my way into the nooks and crannys
    but if it is rediculously hard to put back together [read: above the level of a caveman] then i better not
    its proving harder to clean than i thought with a wire brush and a wire drill bit with brake cleaner.
  10. Nov 29, 2009 at 9:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive the cave men can do it....
  11. Nov 29, 2009 at 9:30 AM
    SilverSeven
    Jordon
    South Jurzee
    got a link to a writeup? my hands are too greasy for online research lol
    also if fluid got out i can replace fluid later?
  12. Nov 29, 2009 at 9:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    I always scrap as much of the thick stuff off and spray it with stuff like ^^^^ and let it soak. Surprisingly, Walmart has a similar cleaner that is cheaper and just as effective.
  13. Nov 29, 2009 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Soorry. Never did a write up on it. :eek:
  14. Nov 29, 2009 at 10:00 AM
    SilverSeven
    Jordon
    South Jurzee
    the splines on my input shaft might be fucked
  15. Nov 29, 2009 at 10:02 AM
    SilverSeven
    Jordon
    South Jurzee
    i need a spline cleaner or something
  16. Nov 29, 2009 at 10:04 AM
    SilverSeven
    Jordon
    South Jurzee
    screwdriver ftw
  17. Nov 29, 2009 at 10:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How boot a tooth brush? :confused:
  18. Nov 29, 2009 at 10:29 AM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
