Cleaning out inside of frame?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kpla51, Jan 31, 2015.
  1. Jan 31, 2015 at 4:53 PM
    kpla51
    kpla51 [OP] Well-Known Member
    Fort Campbell
    Anyone have a technique to do this? When i stick my finger in there I can feel Flakes and corrosion.
  2. Jan 31, 2015 at 5:24 PM
    cep89
    cep89 Well-Known Member
    Michigan
    2017 MGM TRD OR DCSB
    Compressed air and a blow gun
  3. Jan 31, 2015 at 5:32 PM
    kpla51
    Fort Campbell
    what should i spray inside. Id like this to last me a long time. It spent its whole life in Massachusetts and was undercoated by toyota in 09 and it is a 2004. The frame external doesn't look terrible but like i said when i stick my finger in there i can feel chips.
  4. Jan 31, 2015 at 5:46 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Take it to the dealership for inspection. Toyota should cover a replacement frame if need be.
  5. Jan 31, 2015 at 6:06 PM
    kpla51
    Fort Campbell
    What sucks is if its borderline and theres no holes they won't replace it. wich means in a few years after the warranty expires then ill be in trouble.
  6. Jan 31, 2015 at 7:19 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    After toyota undercoated mine i filled the frame with rocksalt and watered it every once and a while….. i figured the undercoat would only delay the corrosion until the warranty expired. it worked pretty well after two years….. was probably ready for new frame after one year actually
  7. Jan 31, 2015 at 7:24 PM
    kpla51
    Fort Campbell
    did you get a new frame?
  8. Jan 31, 2015 at 7:43 PM
    michigander
    michigander Member
    Bob
    Frankenmuth, Michigan
    2001 Dbl. Cab TRD 4x4
    I had same problem, flakes inside frame. Small dime size hole on right side, front leaf spring area. I took to Toyota, they said "Sorry", previous owner did not do frame treatment. I had hole patched over at welding shop and blew out all flakes as best I could. Made up a concoction, with wax rings , non detergent oil and mineral spirits. Plugged all openings on frame and pumped it in , about gallon on each side. Then opened up drain holes. Over a year later I can stick my finger in there and it's still tacky and doing great. I love the truck, but Toyota should have stood behind all these frames.
  9. Feb 1, 2015 at 6:54 AM
    kpla51
    Fort Campbell
    Why would that of mattered if the previous owner didn't do the frame treatment if you have 15 years from the date of manufacturing?
  10. Feb 1, 2015 at 9:24 AM
    kpla51
    Fort Campbell
    Have been doing digging and it seems like if the undercoating was done it will extend the frame warranty for an additional 15 years. Is this true?
  11. Feb 1, 2015 at 12:18 PM
    michigander
    michigander Member
    Bob
    I don't think so! They told me they could not help me because the previous owner, did not take truck to dealer to put frame treatment on. Dealer wanted to do it! They are paid by the factory when they do warranty work, but Toyota would not approve mine.
  12. Feb 1, 2015 at 12:21 PM
    michigander
    michigander Member
    Bob
    If dealer did your undercoating before the cutoff date. Your probably good to go.
  13. Feb 1, 2015 at 12:56 PM
    kpla51
    Fort Campbell
    it was coated in 2010 when was the cuttoff?
  14. Feb 1, 2015 at 1:35 PM
    geodude
    geodude Well-Known Member
    If the truck was inspected and treated with the thick CRT (corrosion resistant treatment) tar by a Toyota service department before the December 2010 deadline (December 2011 only in NY) that frame is most definitely eligible for replacement until 15 years after date of manufacture.
    These frames rust from the inside out, so if your feeling big chips on the inside, I'd imagine the frame is on it's last leg.
    First thing you should do is verify that Toyota has a record of the frame being treated prior to the Dec. 2010 deadline. Take your VIN and call Toyota Service, or go to the ToyotaCare website, and type in your trucks VIN# to view all service history performed by any official Toyota dealership and you should see an event where the CRT was applied.
    If you have had the coating prior to the deadline you are entitled to a free rust check up every year until that 15 year from manufacture warranty expires. Meaning you can bring the truck in once a year and they will inspect the frame for perforation ( hole exceeding 10mm = replacement).
    Tip: Only once you've verified your frame is under the warranty; take a ball peen hammer and tap around the base of the frame, particularly near the leaf shackles looking for soft spots. If you do find a soft spot and want to expedite the eventual, do what I did and put the hammer through it.
    I've been through the process and had my 2002's frame replaced. All of this information comes directly from Toyota with whom I'd spoken in depth with several times about this service campaign.
    I'd be happy to answer any other questions you might have.
  15. Feb 1, 2015 at 1:39 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    [FONT=Verdana, sans-serif]For rust prevention/treatment discussion and alternatives see:
    http://www.tacomaworld.com/forum/2nd...on-thread.html
    [/FONT]
  16. Feb 2, 2015 at 4:26 PM
    kpla51
    Fort Campbell
    just called toyota and i have till nov 2018 for the frame warranty.
    she said she couldn't give me anything saying that in weighting since it will be re issuing a recall and they can't do that.
  17. Feb 3, 2015 at 10:02 AM
    geodude
    Clarify that last part? What is it that Toyota can't give you/won't do?
  18. Feb 3, 2015 at 10:08 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    I'd also like to know this...
