Cleaning parts?
Discussion in '4 Cylinder' started by Noobatized, Dec 9, 2008.
  1. Dec 9, 2008 at 5:22 PM
    Noobatized
    Noobatized [OP] Member
    Inland Empire,CA
    97 Tacoman
    None
    Can you clean the O2 sensor,cat,MAF with chemicals to make them work better?If so what chemicals?
  2. Dec 9, 2008 at 5:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wouldnt mess with the o2 sensors or the catalytic converter............too much chance in messing them up, even if a product says its ok for them. the maf sensor.....you can use an electronics cleaner/electronic contact cleaner.......works pretty good. i use qd electronic cleaner made by crc. and for the throttle body..........i use seafoam deep creep.
  3. Dec 9, 2008 at 5:30 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    X2 on all that. don't mess with the O2 sensors. they're expensive.
  4. Dec 9, 2008 at 5:58 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    There's a cleaner made by CRC specifically for MAFs. Don't mess with the O2 sensor, if you are, just go ahead and replace it instead.
  5. Dec 9, 2008 at 6:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    true....they have a maf sensor cleaner, and the elec. contact cleaner. i have used both without any problems.:)
