Cleaning spare gas tank
Discussion in 'General Automotive' started by Amo-cat3, Feb 23, 2012.
  1. Feb 23, 2012 at 8:45 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Quick question - I have a 6 gallon poly gas tank that i used for mixing two stroke oil and gas. It's been sitting empty for 2 years in my shed. I want to clean it out so i can keep fresh gas in it for the Tacoma. How should i clean/rinse it out, or is it tainted and should not be used for fresh gas for the truck?
  2. Feb 23, 2012 at 8:54 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    i would just buy new one and use that one for bad gas
  3. Feb 23, 2012 at 8:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Was there a cap on it, is it clean inside and you're just worried about the 2-stroke oil? If so, empty it out and fill it with gas. That tiny bit of 2-stroke oil residue on the walls shouldn't be an issue.
    If it's dirty, rinse it with water and make sure it's completely dry before putting gas in. If there's a sludge on the bottom, use something like carb cleaner to dissolve the sludge and again make sure it's dry before putting fuel in.
  4. Feb 23, 2012 at 8:59 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Just dump the old gas out and refill with fresh gas...the little bit of oil shouldn't make a difference.
    Howard
  5. Feb 23, 2012 at 8:41 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Just worried about the two stroke oil. It's been empty for over a year now with the cap on. I guess I'll put some fresh gas in, swoosh it around a few times and dump and air out. That should do it, thanks all.
