cleaning the engine bay
Discussion in 'Detailing' started by nd, Apr 28, 2008.
  1. Apr 28, 2008 at 12:52 PM
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    hey guys, after the Uwharrie trip my engine bay is caked with mud. I was just planning on spraying the hell out of my engine with a hose. is there anything i need to watch out for or be careful around? is there a better way to get my engine mud free?
  2. Apr 28, 2008 at 1:09 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Everything should be pretty much sealed up. When I do clean mine out I always steer clear of the intake (if exposed), fuse box and any other type of wire connections. I'm just overly cautious about those things. Other than those as long as all of your gaskets are in good shape you shouldn't have an issue. Just dont do it right after the engine has been running, rapidly cooling is not the way to go.
  3. Apr 28, 2008 at 1:13 PM
    nd
    Nate
    Greenville, SC
    thanks for the info. i had heard not to do it with a hot engine before but i'm glad you reminded me, i sorta forgot about it...
  4. Apr 28, 2008 at 1:39 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey ND that's a nervous undertaking to me but I would also stay clear of the ignition parts too like the coilpaks just 'cause of them arching etc. If you have access to an air hose you could fluff off alot of the dry mud with the aid of a soft wire brush
  5. Apr 28, 2008 at 1:39 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    the way i look at it...if mud got there...then water will too on a rainy day...sooo...for the most part it shouldnt hurt it too much...just dont go spraying water down any tubes
    i use a hose on mine every now and then and knock on wood have had no issues yet
  6. Apr 28, 2008 at 1:43 PM
    nd
    Nate
    Greenville, SC
    the air hose wont work, the mud is caked about half an inch thick. wire brush wont work either, its EVERYWHERE. I would have to take the engine apart to get to all that.
  7. Apr 28, 2008 at 1:43 PM
    nd
    Nate
    Greenville, SC
    thats what i was thinking. its on the underside of my hood. i assume its no problem.
  8. Apr 28, 2008 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i pressure washed my engine compartment yesterday when i got back......seems to not have hurt anything.....everything is running normal.
