Cleaning Tone Rings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dalmatian, Jul 21, 2012.
  1. Jul 21, 2012 at 7:53 PM
    Dalmatian
    Dalmatian [OP] New Member
    Is it possible to clean the front tone rings on an '05 Prerunner without disassembling the brakes? I ask because I had an ABS light come on, so I replaced the seemingly faulty sensor (it was fairly greasy) and the light is still on. I recently had a shop replace a bad wheel bearing so I'm thinking a greasy tone ring is the cause of my ABS problems.
    Thanks
  2. Jul 21, 2012 at 8:14 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    just pull the sensor and jab a q tip in the hole and spin the tire. It might take a dozen q tips but it will clean out.
  3. Jul 21, 2012 at 8:17 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Like stated above you could remove the sensor and clean out the inside. But I highly doubt that dirt is causing your abs light to be on. You need to have the code scanned to determine what is causing the problem. Otherwise you are just shooting in the dark to correct the problem.
  4. Jul 21, 2012 at 8:18 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    My tone rings were covered with grease and no issues.
  5. Jul 21, 2012 at 8:27 PM
    NelsonTacoma
    Tucson, AZ
    You can check the codes your self. Run a jumper wire to these terminals. Count the blinks. Then you have your code(s). i.e. 5 blinks followed by 6 blinks would be code 56.
    Here's the list of codes.
    Good luck!!
  6. Jul 21, 2012 at 8:48 PM
    Dalmatian
    Sorry I wasn't clear. I had it scanned and the mechanic told me left front ABS sensor. I replaced it but the light is still there, which is why I was thinking maybe grease from the bearing caused the fault. :confused:
  7. Jul 21, 2012 at 9:32 PM
    NelsonTacoma
    Tucson, AZ
    It's also possible that the sensor was not the problem. You could have an open wire or shorted circuit.
    I would get the code cleared and then if it comes back you should check the wires to be sure they are ok.
  8. Jul 22, 2012 at 7:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They are reactance sensors grease has no effect.
  9. Jul 22, 2012 at 11:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    reactance: The resistance to the flow of alternating current due to inductance.
    What you mean is they are inductive sensors. They detect the metal nipples on the Tone Ring which causes a current to be created in the circuit. Grease and oils do not effect their operation.
    Capacitive switches on the other hand can and usually are effected by grease, oils etc...
  10. Nov 11, 2012 at 12:57 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Probably they used a bad quality bearing, and it is not abs ready, so it is giving you this problem....
  11. Nov 11, 2012 at 2:52 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Sorry reluctance. But never mind they can be covered with grease and still work fine.
  12. Feb 21, 2013 at 2:45 PM
    Dalmatian
    Dealer said it wasn't the bearing; it's the ABS control module, and they want to charge $2,400 in parts alone to fix it. I'm not buying it (figuratively or literally).
  13. Feb 21, 2013 at 4:13 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Wow. Eh, you don't need it anyway. I disconnected my ABS several years ago, but I also prefer to drive myself instead of letting the ECU do it.
  14. Feb 21, 2013 at 6:10 PM
    Dalmatian
    The only code the truck threw was code 32: left front wheel sensor.
