Cleaning TRD seat covers
Discussion in 'Detailing' started by Eagledynasty, Feb 16, 2012.
  1. Feb 16, 2012 at 10:27 AM
    Eagledynasty
    Eagledynasty [OP] The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Heyo TW. I got a pair of front TRD seat covers, I believe they are the "neoprene" material and they have a litle of a dirty look to them. Im looking for advice on the best (and safe) way to clean these. Ive heard of people taking them to a laundry cleaners to have them done, and the same story that they destroyed them. Any advice TW?? Thanks :D
    P.S. I tried searching for a thread on this and failed, hopefully it isnt one of those "you should have searched this"
  2. Feb 16, 2012 at 10:34 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I just used a liberal amount of armor all on mine.
  3. Feb 16, 2012 at 10:38 AM
    Eagledynasty
    AJ
    Worcester, MassHole
    Did it get a lot of it up? Did you use the wipes or the armor all interior spray?
  4. Feb 16, 2012 at 11:13 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I use the wipes, seemed to clean it pretty decently
  5. Feb 16, 2012 at 11:20 AM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    I got mine really dirty. Used a fabric pre cleaner, like oxy clean on the fabric and then Murphy's vinyl cleaner on the black section. I scrubed with the oxyclean until the stains came out. Then washed off with a hose in the driveway. looked like new. I wipe them off every so often with a rag and some windex. Unless your using harsh chemicals or scrubing with nails, it would be hard to wreck them.
  6. Feb 16, 2012 at 11:25 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I clean the gray material with soap and water and use aerospace 303 on the black insert.
  7. Feb 18, 2012 at 11:08 AM
    Eagledynasty
    AJ
    Worcester, MassHole
    Cool thanks guys. Gunna try the armor all interior cleaner first just because I have it on hand right now
